Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,767 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I’m working on the front S calipers on the GT build and hit a snag.
The pads do not seem to be for this application. Wondering if different pads are warranted. I know these Porterfields have more meat on them. That could be the reason. The pistons are seated all the way in. (Fresh rebuild). I even tried moving them with a wooden dowel. They budge just enough to collapse seal slightly but when relaxed sit as they are. Am I doing it wrong? (IMG:style_emoticons/default/dry.gif) Help appreciated!! Note: no fluid in system yet. Any brake pad recommendations? Pics Attached thumbnail(s) ![]() ![]() ![]() ![]() Attached image(s) ![]() ![]() |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,174 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Remove the backer plate ?
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Remove the backer plate ? (IMG:style_emoticons/default/agree.gif) Take off the backer plate & run them...after a bit of wear you can fit the plate back in if they're squealing.... Also it's the seals that are pushing the pistons a bit proud of being fully seated....so you could try slipping in the backer plate first then wedging the pad in--might work... |
Lo-Fi Version | Time is now: 17th June 2024 - 02:27 AM |
