GeorgeKopf |
Member ![]() ![]() Group: Members Posts: 223 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region ![]() |
I'm starting a restoration project and I'm looking for advice on almost any topic. Please feel free to contributed nonsequiturs and random philosophical ideologies.
The chassis is in fairly good shape and is "mostly" stripped. I still have to remove the wiring harness and some fuel lines. It is my intention to have it blasted or dipped. The idea is to enjoy the build! Having it and driving it will be cool too but for me the real journey is the creative construction project. To that end, I'll be focusing on building a car that is fun (and reliable). My goal is to get the car on the road by its 50th birthday (2024) and to have it last another 50 years. I'm not too worried about being stock nor do I intend to sell it. The engine came with dual weber carburetors, (no EFI components) and supposedly the PO didn't like how it ran. I think I'm going to have to split the case to figure out what the PO might have done. Here are some of my random questions: 1. How do you protect the longs from rusting from the inside? 2. What happens to the heater tubes in the longs if you acid dip the chassis? 3. How big can I build the motor without sacrificing reliability/longevity? 4. Should I sell the Weber carbs and buy an aftermarket EFI system? 5. How do you flat-tow the chassis without the transmission in place? 6. Is it possible to reinforce the doors? They seem awfully flexible and dent prone. 7. If I put low-profile tires on the car, how do I recalibrate my speedometer? 8. What is the right welder that I should buy to work on the body panels? (I don't know how to weld but I have some extra doors that I can practice on). Sincerely. George |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If acid dipping they often paint dip after acid. Ask the dip shop what steps they do. 2. What happens to the heater tubes in the longs if you acid dip the chassis? Gone, you would have to cut into the long to replace. 3. How big can I build the motor without sacrificing reliability/longevity? As big as your wallet, cast iron cylinders 96mm or nickies for bigger cylinders. 4. Should I sell the Weber carbs and buy an aftermarket EFI system? I'd get it running on carbs first. EFI has a steep learning curve and isn't cheap. 5. How do you flat-tow the chassis without the transmission in place? You can't, flatbed, trailer or install the trans. 6. Is it possible to reinforce the doors? They seem awfully flexible and dent prone. Not an issue. 7. If I put low-profile tires on the car, how do I recalibrate my speedometer? You want to keep the tires close to stock diameter or the wheel wells look odd. You want to stay around 24" OD. 8. What is the right welder that I should buy to work on the body panels? (I don't know how to weld but I have some extra doors that I can practice on). Small name brand (Lincoln, Miller, Holbart, etc) MIG welder with a bottle of argomix gas. I have a 120 volt/20amp Miller 130. Practice on thicker metals first, sheet metal takes practice. |
Lo-Fi Version | Time is now: 24th June 2025 - 12:59 AM |
