bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,494 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
What do you all think of this location for mounting my new pump in the front?
Besides space, I have some other goals: 1. Avoiding mounting on any sheet metal shared with the passenger compartment. 2. As much protection as possible. 3. Short fuel line runs between the tank, filter, pump, and hard lines. 4. Access to the lines without pulling the tank. 5. Access to the pump without pulling the tank. My proposed location probably does not satisfy goal 5 (maybe), but otherwise I like it. Attached thumbnail(s) ![]() |
bkrantz |
I do know about the stock 75-76 location on the left side, but I prefer not to cut an access hole in the bulkhead. With my proposed location, I might be able to remove the pump through the existing big round hole.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,804 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I do know about the stock 75-76 location on the left side, but I prefer not to cut an access hole in the bulkhead. With my proposed location, I might be able to remove the pump through the existing big round hole. (IMG:style_emoticons/default/agree.gif) That can be removed easily if both fasteners are through the big hole panel. Move it down a bit. Include enough hose to allow it to be removed through the hole with hoses attached. I did it that way. |
Lo-Fi Version | Time is now: 8th September 2025 - 05:04 AM |
