> Motor oil, What weight?
911914
post Dec 27 2004, 11:33 PM
I am sure this has been hashed out here many times before and I don't want to start another oil thread but I be a newbie. Car I just purchased was rebuilt about 20k ago ('74 2.o) and the records show 15-40 weight has been used since rebuild and at all services. Now is this not a heavy diesel weight oil? I use this weight in my BMW 535i as recommended from factory, but a small air cooled VW mill using this heavy weight? Doesn't sound right to me. Clue me in please. Oh, engine is dual Weber's and a Web cam.
Thanks.
ChrisReale
post Dec 28 2004, 04:20 AM
Sleazy
15-40 is prolly Shell Rotella, which is a good oil designed for deisel engines, but fully compatable with a VW engine. Personally, I broke my engine in on Kendall 20-50 and switched to Mobil 1 15-50. Basically, anything 10-40 or heavier is going to be ok, although 20-50 is an ideal weight
911914   Motor oil   Dec 27 2004, 11:33 PM
markb   I use 20/50 in the 914s & the Bus (2.4/6).   Dec 28 2004, 12:23 AM
911914   Thanks Mark, I too use the 20-50 (Castrol) in my A...   Dec 28 2004, 12:40 AM
ChrisReale   15-40 is prolly Shell Rotella, which is a good oil...   Dec 28 2004, 04:20 AM
type11969   I use 5w-30 and have plenty of pressure all around...   Dec 28 2004, 07:12 AM
911914   New twist to my oil question. Called the PO engin...   Dec 28 2004, 01:18 PM
Root_Werks   Woah you guys, you are all giving great advise, bu...   Dec 28 2004, 01:30 PM
SirAndy     Dec 28 2004, 01:32 PM
Rhodes71/914   I've always used 10-40 in all my VW aircooled ...   Dec 28 2004, 01:54 PM
7391420   kendal straight 30 in winter, straight 50 in summ...   Dec 28 2004, 02:04 PM
Cap'n Krusty   <...   Dec 28 2004, 03:06 PM
type11969   how can you say it is too thin if I have plenty of...   Dec 28 2004, 03:23 PM
SirAndy   htt...   Dec 28 2004, 04:40 PM
ChrisReale   Forget the weight, just make sure you use oil, per...   Dec 28 2004, 11:46 PM
dlo914   20w50 / W = Winter NOT Weight ...   Dec 29 2004, 12:42 AM
dlo914   use higher winter if your region is prone to very ...   Dec 29 2004, 12:46 AM
Tom73   My understanding has always been that a 10w30 wi...   Dec 29 2004, 09:56 AM
type11969   yeah, my understanding is the same as yours Tom. I...   Dec 29 2004, 10:19 AM
rdauenhauer   So what about the "newer car" spec 0-40 syn oils (...   Dec 29 2004, 10:32 AM
type11969   The problem I have with mobil one in a t1 or a t4 ...   Dec 29 2004, 11:21 AM
Steve   According to Bruce Anderson in Tech notes II, this...   Dec 29 2004, 11:41 AM
Aaron Cox   larger number = thicker oil right? 50= THICK 10= ...   Dec 29 2004, 11:45 AM
Steve   The higher the number the thicker the oil. I remem...   Dec 29 2004, 11:50 AM
type11969   I seem to remember Jake stating that he had proble...   Dec 29 2004, 12:26 PM
dlo914   http://www.914world.com/bbs...   Dec 29 2004, 12:29 PM
Tom73     Dec 29 2004, 05:25 PM
Steve     Dec 29 2004, 08:22 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:34 PM
