> 914World Classifieds Rules
> FS: Parts lot
partwerks
post Feb 7 2021, 05:45 PM
For sale: Parts lot
All used parts.
Cash if local pickup, or paypal if being shipped.
Shipping on top of stated price.
1. Relay board-came off of a running car, but has been sitting out in the elements for about 3 months, but very little moisture during those months. $42.00
2. Front hood hinges & springs-$41.00
3. Rear deck lid hinges-$20.00
4. Trunk torsion bars & clamps-$25.00
5. Window crank-$1.00
6. Hood release cable (no plastic tube) $25.00
7. Trunk light-$5.00
8. Relay board cover-has cut/crack on top, and a piece of corner broke off-$1.00
Knob, and bolt are SOLD.
9. Battery hold down clamp-$2.00
10. Front targa latches-one has a good handle, but bent hook, and the other one has a cracked handle, but good hook. Can make one good handle out of them both. $18.00
11. Front lower hood latch-$31.00
12. Used 200# springs-$40.00-SOLD
13. Dog bones, two-$10.00-SOLD
14. Clutch stop-$4.00-SOLD
15. Fuse box-$9.00
16. Fresh air vent tube grommets (pair) $5.00
17. Brake reservoir-$4.00-SOLD
18. Tripometer cable-$15.00-SOLD
19. Window channel sealing rails-one rail has two holes that are over sized-$15.00-Sold
20. Driver side vertical rollbar pad-$10.00-SOLD
21. Glove box locks (2) A bit rough around the front. One is complete, the other isn't-$20.00-Sold
22. Trans ground cable-$2.00-SOLD
23. Windshield pillar pads-has some material missing in the corners-$30.00-SOLD
24. L defroster duct-has inner tab broken off-$10.00
25. Control box pieces-Control box has some metal bracket parts broken off sides. Otherwise all have the tabs intact-$22.00
26. Clutch cable bracket w/bushing-$5.00
27. Clutch cable clevis-$5.00-SOLD
28. Pedal board hold down clamp (Pyramid shaped) $1.00-SOLD
29. Fuel pump bracket-$5.00-SOLD
30. After market rear swaybar-$50.00-SOLD
31. Steering column. Missing small screws for ignition switch retainer bezel around ignition lock on the front. No key. $114.00
partwerks
post Mar 14 2021, 07:54 PM
Bump
partwerks   FS: Parts lot   Feb 7 2021, 05:45 PM
Literati914   I'm interested in the aftermarket rear sway ba...   Feb 7 2021, 05:57 PM
partwerks   I'm interested in the aftermarket rear sway b...   Feb 7 2021, 06:04 PM
frostyf   Couldn't see the a frame pads: And keen to ...   Feb 7 2021, 06:03 PM
partwerks   Couldn't see the a frame pads: And keen to...   Feb 7 2021, 06:25 PM
ndfrigi   edited: since someone already ahead of me for #23 ...   Feb 7 2021, 06:03 PM
Literati914   .. besides the rear sway bar(30), I'd also lik...   Feb 7 2021, 06:05 PM
partwerks   .. besides the rear sway bar(30), I'd also li...   Feb 7 2021, 06:15 PM
cork   i'll take the ground strap and dog bones, plea...   Feb 8 2021, 08:26 AM
partwerks   Bump   Feb 11 2021, 07:19 PM
StarBear   I’ll take #8 cover with post and knob. Will pm w...   Feb 11 2021, 07:41 PM
partwerks   Bump   Feb 17 2021, 07:56 PM
ClayPerrine   Just a note to whomever bought the rear sway bar. ...   Feb 18 2021, 07:24 AM
B2524   Ill take the 200lbs springs PM PP info and total S...   Feb 18 2021, 07:31 AM
rgb91424   I would like the clutch stop for pedal board #14 a...   Feb 19 2021, 04:25 PM
partwerks   Bump   Feb 23 2021, 09:02 PM
partwerks   Bump   Mar 14 2021, 07:54 PM
partwerks   Bump   Apr 7 2021, 06:13 PM
mgp4591   PM sent.   Apr 7 2021, 08:38 PM
56kabrio   PM sent. I'd like the a pillar pads and th...   Apr 8 2021, 12:27 AM
Medtner3   any chance you have another relay board cover with...   Apr 9 2021, 09:00 PM
partwerks   any chance you have another relay board cover wit...   Apr 9 2021, 09:18 PM
- Lo-Fi Version Time is now: 29th October 2026 - 08:18 PM
