Auto paint question, Bodywork |
r_towle |
Mar 15 2021, 08:37 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bare metal flares, the rest of the body is painted
So the question is for bare metal. Order options 1) epoxy primer, bondo, high fill primer, sealer, paint, clear OR 2) bondo, high fill primer, sealer, paint, clear What would you suggest? And, given my lack of a paint booth, I will have a paint shop do whatever stage I need to ensure no bugs land on the paint. I will paint and bodywork up till it must be a clean room process. I need some advice on the steps and order. Rich |
slowrodent |
Mar 16 2021, 08:12 AM
Member Group: Members Posts: 120 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region |
My only concern with option 1 is that the epoxy primer be sanded if it is allowed to completely cure prior to filler application. There's generally a recommended window where the filler can be applied without sanding, but after full cure, it probably should be sanded prior to ANYTHING being applied on top.
Option 1, with this stipulation, has been my approach thus far. |
roblav1 |
Mar 16 2021, 12:34 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
DP40LF is 24 hours.
My only concern with option 1 is that the epoxy primer be sanded if it is allowed to completely cure prior to filler application. There's generally a recommended window where the filler can be applied without sanding, but after full cure, it probably should be sanded prior to ANYTHING being applied on top. Option 1, with this stipulation, has been my approach thus far. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:04 PM |
