Torque Spec Needed, Rear Brakes |
Ansbacher |
Mar 17 2021, 12:37 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks.
Ansbacher |
JeffBowlsby |
Mar 17 2021, 01:39 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
bdstone914 |
Mar 18 2021, 06:54 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks. Ansbacher According to the Tech Specs book: M12 x 1.5 x 30? 7.0 ft lbs I cant believe it is 7 ft lb. Did you add a decimal in error? @JeffBowlsby |
JeffBowlsby |
Mar 18 2021, 08:17 AM
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks. Ansbacher According to the Tech Specs book: M12 x 1.5 x 30? 7.0 ft lbs I cant believe it is 7 ft lb. Did you add a decimal in error? @JeffBowlsby You're right Bruce I should have questioned that. Turns out its more likely "7.0 mkg" = 50 ft lbs. Of the several torque value tables in the Tech Specs book, only one has the units mkg indicated all other tables do not show units. Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:36 AM |
