> Sound installation for interior, Experience and suggestions
Mcraneiowa
post Mar 18 2021, 05:45 PM
I purchased a couple rolls of Farman adhesive backed sound material with the aluminum foil top. Curious what everybody’s thoughts are for using this in the interior, on the floors and behind the back panel.
Thinking simply roll/press it down with a roller and then tape the seams. Are there other ways or material that people prefer to use as I keep thinking of the moisture that at some point will likely get under the sound insulation material even if I tape it.
FYI, I did replace the floors then coated entire floor top and bottom with Por15, followed up with paint so I’m starting with a very nice surface. I know I can put this down and will be fine for probably at least 15 or 20 years but I would like to think I could make it last longer so the next guy won’t have to worry about rust. Like to know what others have done and what their experiences are.Attached Image Attached Image
mate914
post Mar 19 2021, 08:10 AM
Matt
I tried this... Now its not quieter, is duller. Nest time I plan on using spray on acoustic stuff.... Any NASA guys here have access to any? I like using modern tech in our old cars.
Matt
horizontally-opposed
post Mar 19 2021, 09:32 AM
QUOTE(mate914 @ Mar 19 2021, 07:10 AM) *
Matt
^ This is a very interesting input.
Can you elaborate a bit more, both on what you did and your observations? Going to redo my floors at some point, and have been watching these threads with keen interest.
Fwiw, a visit to the restoration shop that handles restoration work for Porsche Classic revealed 997 (?) sound deadening mats instead of the old-school stuff. Kind of a gray, diamond-shaped pattern iirc. I suspect the choice was driven by a matter of cost, weight, effectiveness, and/or environmental impact/legislation. But I'd like to learn more, and suspect that whatever Porsche and other manufacturers is about as good as it gets in terms of those four parameters.
Mcraneiowa   Sound installation for interior   Mar 18 2021, 05:45 PM
Tdskip   There have been some very detailed discussions and...   Mar 18 2021, 08:00 PM
horizontally-opposed   There have been some very detailed discussions an...   Mar 18 2021, 08:21 PM
JmuRiz   Has anyone installed the sticky stuff cut to fit i...   Mar 18 2021, 08:55 PM
Sycolyst   As you can see, I placed the sound/insultation mat...   Mar 19 2021, 05:47 AM
mate914   I tried this... Now its not quieter, is duller. N...   Mar 19 2021, 08:10 AM
horizontally-opposed   I tried this... Now its not quieter, is duller. ...   Mar 19 2021, 09:32 AM
Tdskip   On a related note, and because this was brought up...   Mar 19 2021, 09:49 AM
Olympic 914   On a related note, and because this was brought u...   Mar 19 2021, 10:01 AM
horizontally-opposed   On a related note, and because this was brought u...   Mar 19 2021, 10:11 AM
Tdskip   On a related note, and because this was brought ...   Mar 19 2021, 10:53 AM
mate914   After changing the floor pans. After owning the ca...   Mar 19 2021, 10:05 AM
pcdarks   My 72 already had sound/heat insulation on the bac...   Mar 19 2021, 10:36 AM
mate914   Has anyone tried lizard skin?   Mar 19 2021, 10:41 AM
CptTripps   Has anyone tried lizard skin? Not yet, but was p...   Mar 19 2021, 10:51 AM
914sgofast2   Make sure you reseal the rear window. Water, as we...   Mar 19 2021, 10:50 AM
horizontally-opposed   I've wondered about this stuff—which is supp...   Mar 19 2021, 11:06 AM
Mark Henry   IMHO I'm not impressed with any of the afterma...   Mar 19 2021, 12:11 PM
bbrock   Keep in mind that different sound deadening materi...   Mar 19 2021, 01:36 PM
Mark Henry   The firewall mat works because it's a heavy ru...   Mar 19 2021, 02:20 PM
- Lo-Fi Version Time is now: 9th July 2025 - 12:26 PM
