Mcraneiowa |
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None ![]() |
I purchased a couple rolls of Farman adhesive backed sound material with the aluminum foil top. Curious what everybody’s thoughts are for using this in the interior, on the floors and behind the back panel.
Thinking simply roll/press it down with a roller and then tape the seams. Are there other ways or material that people prefer to use as I keep thinking of the moisture that at some point will likely get under the sound insulation material even if I tape it. FYI, I did replace the floors then coated entire floor top and bottom with Por15, followed up with paint so I’m starting with a very nice surface. I know I can put this down and will be fine for probably at least 15 or 20 years but I would like to think I could make it last longer so the next guy won’t have to worry about rust. Like to know what others have done and what their experiences are. ![]() ![]() |
pcdarks |
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None ![]() |
My 72 already had sound/heat insulation on the back. I put it inside my doors and they sound a lot more solid when I close them. They don't sound like a tuna can now. it's got to help with road noise. I was a little reluctant to put it on the floor thinking it may trap moisture and promote rust.
Lo-Fi Version | Time is now: 9th July 2025 - 12:35 PM |
