> 914 ITB's, Pro's and Cons, option opinions and show us your setup!!
Steve
post Mar 23 2021, 02:15 PM
It seems like ITB's are all the rage with our air cooled sixes.
The throttle bodies are either PMO or direct to head either with butterflies or AT-Power with no butterflies.
Mark dug up some of the pricing!! Thanks Mark!!
X-Faktory uses Megasquirt, Link or Motec M84
https://www.x-faktory.com/uploads/6/3/9/3/6...efi_systems.pdf
Starting at $4754
Clewett uses TEC
https://www.clewett.com/index.php?main_page...dex&cPath=2
Starting at $8400
Rasant uses exclusively Motec, which is the most expensive
https://rasantproducts.com/collections/mote...84-ecu-packages
Starting at $5700 for the ITB's and $6200 for the EFI
AT-Power offers throttle bodies without butterflies, but use special cams to optimize
https://www.atpower.com/
Starting at $13K
Lots of options which can raise or lower the price.
I have a stock Euro 3.2 with DME that does run fine, but I miss the sound of the webers, but I don't miss the hassle of webers, cold start, poor gas mileage, etc.
I know ITB's are expensive, but option 2 at X-Faktory is not that bad and pretty popular over on the Pelican 911 technical forum.
Anybody on this forum have any experience with any of these toys?
post Mar 24 2021, 04:46 PM
914-6 GT in waiting
I purchased VEMS for my 3.2 but haven't installed it yet. It doesn't change the look of the induction, just modernizes the electronics and programing and is plug and play to the existing wire harness.
Steve
post Mar 24 2021, 10:57 PM
QUOTE(mepstein @ Mar 24 2021, 03:46 PM) *
What does it include? There website is horrible and I don't see any installation manuals. I also have a mustang MAF with adapter that works with stock DME. I noticed a small uptick with wide open throttle. Otherwise at low RPM's it didn't do much. In Bruce Anderson's book he said a MAF is good for around 10hp, chip for another 10hp and better exhaust for around another 10hp. I already have a Steve Wong chip and ben's heat exchangers. The chip and ben's heat exchangers have been the best improvement so far.
post Mar 25 2021, 07:12 AM
914-6 GT in waiting
QUOTE(Steve @ Mar 25 2021, 12:57 AM) *
I purchased it through Peep, Raceboy on Pelican. He builds a wire harness for it so it can plug into the stock 3.2 harness. I mostly purchased for a custom 3.2 I'm building with hot cams, 3.4 cylinders, max moritz pistons, higher compression, etc. It uses the stock 3.2 reference sensors and modern injectors.
I don't think the FI adds power but will be very tunable to let the engine achieve it's best results. It was ~ $1,200
It sounds like you've already attended to the low hanging fruit with the chip and exhaust. While you might see your engine as a bit boring, I would be really hesitant to touch it. One of the best things about a 3.2 is it's "boring" ability to start and run smooth and dependably when you turn the key.
Steve   914 ITB's   Mar 23 2021, 02:15 PM
roblav1   I had an 84 911 with a 3.2 and altered and install...   Mar 23 2021, 03:01 PM
michelko   I did my setup with triumph speed triple throtzle...   Mar 23 2021, 03:04 PM
mepstein   Slippery slope :D   Mar 23 2021, 03:22 PM
Steve   Slippery slope :D :agree: If your going for h...   Mar 23 2021, 03:36 PM
mepstein   Slippery slope :D :agree: If your going for ...   Mar 23 2021, 04:37 PM
pete000   Slippery slope :D :agree: Also   Mar 23 2021, 07:19 PM
worn   I have a stock Euro 3.2 with DME that does run fi...   Mar 23 2021, 03:31 PM
Steve   I have a stock Euro 3.2 with DME that does run f...   Mar 23 2021, 03:43 PM
Luke M   On my 3.4 build I went with the Rasant Products/PM...   Mar 23 2021, 04:59 PM
Steve   On my 3.4 build I went with the Rasant Products/P...   Mar 23 2021, 05:16 PM
Luke M   On my 3.4 build I went with the Rasant Products/...   Mar 23 2021, 06:00 PM
Coondog   James Patrick pitched this to me last month with a...   Mar 23 2021, 06:25 PM
Steve   James Patrick pitched this to me last month with ...   Mar 24 2021, 08:27 AM
Mark Henry   [quote name='Coondog' post='2902050' date='Mar 23...   Mar 24 2021, 09:42 AM
horizontally-opposed   Honestly, I'd love a way to run 3.2 Motronicâ€...   Mar 23 2021, 10:28 PM
Maltese Falcon   This is a 3L SC engine with upgraded cams, Borla i...   Mar 23 2021, 10:52 PM
Mark Henry   One thing about all these ITB systems is if your e...   Mar 24 2021, 06:18 AM
horizontally-opposed   One thing about all these ITB systems is if your ...   Mar 24 2021, 06:24 AM
john77   i was lurking on this thread wondering if this was...   Mar 24 2021, 05:27 PM
Mark Henry   i was lurking on this thread wondering if this wa...   Mar 25 2021, 06:53 AM
ConeDodger   ITB's can pretty much force you to tune by thr...   Mar 24 2021, 09:36 AM
Mark Henry   It seems like ITB's are all the rage with our...   Mar 24 2021, 03:48 PM
mepstein   I purchased VEMS for my 3.2 but haven't instal...   Mar 24 2021, 04:46 PM
Steve   I purchased VEMS for my 3.2 but haven't insta...   Mar 24 2021, 10:57 PM
mepstein   I purchased VEMS for my 3.2 but haven't inst...   Mar 25 2021, 07:12 AM
Mark Henry   [quote name='Steve' post='2902535' date='Mar 25 2...   Mar 25 2021, 10:15 AM
mepstein   There's nothing wrong with lipstick but unfort...   Mar 24 2021, 05:41 PM
Steve   Thanks everyone for the responses and feedback. I...   Mar 25 2021, 10:43 AM
ClayPerrine   When I built the 4.0 monster motor, I debated on I...   Mar 25 2021, 11:02 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:31 PM
