DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have been dealing with this for 12 years, a non-running defrost fan. i even pulled this out 2 years ago and rebuilt it with new flapper seals and main body seal then made sure fan turned but didnt bench test the motor or resisitors, so as a result it still does not work properly. i will be documenting this because 914rubber and Mark will soon be putting together a kit for this that includes all the hardware seals and even a motor i believe, BUT i still have problems and questions!!! so i am starting this thread to get information on diagnosing the common causes of it not working and how to fix it, and then document the rebuild and replacement of the motor, fan, resistor and maybe the control unit in dash. Others have documented the reinstallation of the fan and the cables so i will not duplicate that. and we may want to link other threads hear that have done that as well.
Mark is sending me a kit soon, so while i wait for it, i will have to get some more information about the wiring and resistors function and how to test them . I had this out last week and tested 3 different control units due to thinking that my issue was a control issue, because it runs on one speed, #2, and anything else does not work and it will then throw the fuse. most assume this would be caused by bad slider unit but i tested 3 of them and 2 are like new with no wear on the sliders , still same result. so i am suspecting the resistors /plug aparatus . If anyone has done this and cares to share how to examine and test that for proper function, lets start there. Resistor function, which lead is which and examination of the control units I will take pictures of mine tonight and post those soon. once this figured out and fixed i will do a full step bystep on reassembly too. Looking for lots of help and input on this, thanks!!! Dr. Phil |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
Quick question and I don’t have a schematic in front of me to verify. But are the controls fully installed in the dash? And by that I mean is it bolted to the firewall using the 10mm bolt? It’s a bit foggy but I seem to recall only having one speed until I bolted the controls to the firewall.
DRPHIL914 |
Quick question and I don’t have a schematic in front of me to verify. But are the controls fully installed in the dash? And by that I mean is it bolted to the firewall using the 10mm bolt? It’s a bit foggy but I seem to recall only having one speed until I bolted the controls to the firewall. yes, it is. oh and after reviewing again the schematic and my pictures and referencing another source, Superhawk996 had me go back and compare and due to my plug housing being cracked and gone, the wire had been crossed and i am pretty sure that they are not on the correct pin locations on the fan housing SO.... when i get home these will be moved, but i will test the unit first by using aligator clip to a chassis ground and test each separate ground on the pins, taking the control unit out of the equation. will see how this test goes , along with just verifying i have a full 12v at the fan coming from the fuse board. if its not, i have other issues.. |
Lo-Fi Version | Time is now: 17th June 2024 - 09:29 AM |
