| Olympic 914 |
Mar 27 2021, 05:18 PM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Car started going to an intermittent lean condition.
'73 2.0 d-jet system 037 ECU. Starts up fine, idles Ok. But when I start to drive it, it starts running bad and the AFR goes to 17-18, Sometimes if I feather the throttle I can keep it running and it settles back to 12.5 – 13.0, normal running. Other times it dies. It will start right up again though. I have a fuel pressure gauge but it is mounted in the engine compartment and I can’t see it when driving. Pressure is set at 29 now. and holds at that during idle In January I had an issue with the fuel pump wiring, So I redid the wiring with 12ga from the rear to the front. I didn’t like the sound of the Bosch 044 pump, it was way too loud. So I installed a Bosch 69133 pump. Much quieter, drove it around for a while and everything was working perfectly. Spent all of February doing a cut and buff on the car, then drove it for a bit again everything still working fine. The most recent thing I did was remove the rear brakes to fix my parking brake. Didn’t touch anything in the engine compartment. But when I took it for a drive after working on the brakes the lean condition arose. I had already purchased a FI harness from Bowlsby So I took the opportunity to install it. Hoping that would solve the problem. Well it didn’t. Have a ¼ tank of gas, and I checked it with a dowel rod to make sure the gauge wasn’t reading off. Then added 2 gallons anyways. Still no change. Changed out the fuel pump relay, No improvement. I have no idea what brought this problem on. I can’t rule out the new fuel pump. But it ran good with it for at least 200 miles. Changed the fuel filter and cleaned the screen when I had the tank out. the screen wasn't dirty though. The tank was cleaned before I put it back in 4 years ago. No rust inside. At this point I won’t go further than around the block, and it will happen a couple times on each trip around. But hasn’t stuck me totally yet. Guess I could set up the endoscope to watch what the fuel pressure reads when it goes lean and take it from there. I have to just walk away from it for a while, but my mind is reeling. |
| JeffBowlsby |
Mar 27 2021, 06:48 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
You are doing the right thing to monitor your fuel pressure, it could be the key.
With the new harness that removes electrical related issues assuming all connections are well seated. Clogged or defective injector(s) restricting fuel delivery? Bad trigger points skipping a few pulses now and then? Bad ECU? Bad MPS? Bad TPS? |
| Olympic 914 |
Mar 27 2021, 07:46 PM
You are doing the right thing to monitor your fuel pressure, it could be the key. With the new harness that removes electrical related issues assuming all connections are well seated. Condition existed before installing the new harness, spent much time making sure the boots were sealed and connections were tight. Clogged or defective injector(s) restricting fuel delivery? Bad trigger points skipping a few pulses now and then? 123 d-jet dizzy, built in trigger points Bad ECU? usually bulletproof Not out of the question Bad MPS? Have others to try, but it would tend towards rich rather than lean, right? Bad TPS? Maybe check this also |
Olympic 914 Mystery D-Jet lean condition. Mar 27 2021, 05:18 PM
wonkipop i don't have a d jet, but a 1.8 L jet.
but exp... Mar 28 2021, 03:06 AM
Flyingmonkey I think Jeff is on the right track. TPS, MPS are ... Mar 29 2021, 06:21 AM
dlee6204 I would suggest getting a longer piece of fuel hos... Mar 29 2021, 06:59 AM
DRPHIL914 dont rule out a bad MPS just due to lean condition... Mar 29 2021, 09:58 AM
Olympic 914 I have narrowed the problem down to a fuel / fuel ... Mar 29 2021, 10:05 AM
wonkipop where is the pump located.
under engine bay locati... Mar 29 2021, 04:32 PM
Olympic 914 Removed the tank and confirmed that there was rest... Mar 30 2021, 06:44 AM
ChrisFoley I use half inch racing hose for the 12mm section b... Mar 30 2021, 08:25 AM
Olympic 914 Solved it.
The problem was the fuel lines were ki... Mar 30 2021, 05:21 PM
BeatNavy Nice job, Tom! :Qarl: Mar 30 2021, 05:40 PM
wonkipop great.
be thankful you can still get to the hoses ... Mar 30 2021, 09:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:32 PM |
