Headlights and brake lights don't work looking for guidence |
mb911 |
Mar 23 2021, 05:06 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hi all. The 5 year project is wrapping up. I am working on making it street legal.
Here is what I have 74 chassis harness 914-6 column. Remove the head light relay from the 4cyl. Previous to that the headlights would not turn on anyway. If I jumper the yellow wire on the fuse panel #3 position then the low beam stays on. This is regardless of using the 914-6 column or not. The fogs work, running lights work , turn signals work. Brake lights dont but there were cut wires on the harness down by the switch so that is likely part of the problem. I am also wanting to put relays on each headlight up front like 911s do to prevent any wire fire (IMG:style_emoticons/default/wink.gif) so my question is why the #3 buss wouldn't be energized without jumpering as shown in my picture. My hopes are 2 fold. I am looking for a good high def picture of the brake light switch and wiring on a 74. Then I am looking for the #3 buss(yellow wire low beam) issue. Thoughts? Note in the picture I have the jumper hanging in mid air not attached. Attached thumbnail(s) |
mb911 |
Mar 28 2021, 03:06 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 01:48 AM |
