| Olympic 914 |
Mar 27 2021, 05:18 PM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Car started going to an intermittent lean condition.
'73 2.0 d-jet system 037 ECU. Starts up fine, idles Ok. But when I start to drive it, it starts running bad and the AFR goes to 17-18, Sometimes if I feather the throttle I can keep it running and it settles back to 12.5 – 13.0, normal running. Other times it dies. It will start right up again though. I have a fuel pressure gauge but it is mounted in the engine compartment and I can’t see it when driving. Pressure is set at 29 now. and holds at that during idle In January I had an issue with the fuel pump wiring, So I redid the wiring with 12ga from the rear to the front. I didn’t like the sound of the Bosch 044 pump, it was way too loud. So I installed a Bosch 69133 pump. Much quieter, drove it around for a while and everything was working perfectly. Spent all of February doing a cut and buff on the car, then drove it for a bit again everything still working fine. The most recent thing I did was remove the rear brakes to fix my parking brake. Didn’t touch anything in the engine compartment. But when I took it for a drive after working on the brakes the lean condition arose. I had already purchased a FI harness from Bowlsby So I took the opportunity to install it. Hoping that would solve the problem. Well it didn’t. Have a ¼ tank of gas, and I checked it with a dowel rod to make sure the gauge wasn’t reading off. Then added 2 gallons anyways. Still no change. Changed out the fuel pump relay, No improvement. I have no idea what brought this problem on. I can’t rule out the new fuel pump. But it ran good with it for at least 200 miles. Changed the fuel filter and cleaned the screen when I had the tank out. the screen wasn't dirty though. The tank was cleaned before I put it back in 4 years ago. No rust inside. At this point I won’t go further than around the block, and it will happen a couple times on each trip around. But hasn’t stuck me totally yet. Guess I could set up the endoscope to watch what the fuel pressure reads when it goes lean and take it from there. I have to just walk away from it for a while, but my mind is reeling. |
| BeatNavy |
Mar 30 2021, 05:40 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Nice job, Tom! (IMG:style_emoticons/default/piratenanner.gif)
Olympic 914 Mystery D-Jet lean condition. Mar 27 2021, 05:18 PM
JeffBowlsby You are doing the right thing to monitor your fuel... Mar 27 2021, 06:48 PM
Olympic 914
You are doing the right thing to monitor your fue... Mar 27 2021, 07:46 PM
wonkipop i don't have a d jet, but a 1.8 L jet.
but exp... Mar 28 2021, 03:06 AM
Flyingmonkey I think Jeff is on the right track. TPS, MPS are ... Mar 29 2021, 06:21 AM
dlee6204 I would suggest getting a longer piece of fuel hos... Mar 29 2021, 06:59 AM
DRPHIL914 dont rule out a bad MPS just due to lean condition... Mar 29 2021, 09:58 AM
Olympic 914 I have narrowed the problem down to a fuel / fuel ... Mar 29 2021, 10:05 AM
wonkipop where is the pump located.
under engine bay locati... Mar 29 2021, 04:32 PM
Olympic 914 Removed the tank and confirmed that there was rest... Mar 30 2021, 06:44 AM
ChrisFoley I use half inch racing hose for the 12mm section b... Mar 30 2021, 08:25 AM
Olympic 914 Solved it.
The problem was the fuel lines were ki... Mar 30 2021, 05:21 PM
wonkipop great.
be thankful you can still get to the hoses ... Mar 30 2021, 09:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:32 PM |
