> What do the air plenum flaps do?
Grosbard
post Mar 30 2021, 04:33 PM
Hi all! I'm curious what the air plenum flaps do, and I'm hoping someone can educate me, please. I'm referring to the parts mentioned in this thread:
http://914world.com/bbs2/index.php?showtopic=349044
My guess is that they prevent water and rocks and other stuff from getting to the air-cooled fan...am I correct? Would missing these flaps hurt engine cooling? (I can't see how, but I might be missing some part of the picture)
Also, what makes the flaps open? Just the low air pressure on the intake side of the fan?
Thanks for your help!
Mark Henry
post Mar 30 2021, 04:55 PM
that's what I do!
Yes they work on air pressure and yes they actually do work.
The heat exchangers have two sources of fresh air, the crank fan and an electric fan. With the electric fan on it opens and closes as the engine goes from idle to higher speeds, it maintains a more constant air pressure.
Grosbard
post Mar 30 2021, 05:01 PM
QUOTE(Mark Henry @ Mar 30 2021, 03:55 PM) *
Ah, thank you Mark! So let me rephrase to make sure I understand properly: The presence or lack of flaps doesn't affect engine air-cooling. They're just there to be able to heat the cabin at low engine speed when there isn't enough air flow from the engine air-cooling fan.
barefoot
post Mar 30 2021, 06:07 PM
[/quote]
Correct, with electric heater fan on with engine speed low, they close to force more air thru the heat exchangers for cabin heat
- Lo-Fi Version Time is now: 3rd July 2025 - 04:04 PM
