whiterabbit |
Rust Saver ![]() Group: Members Posts: 28 Joined: 10-March 20 From: Northwest Ohio Member No.: 24,014 Region Association: Upper MidWest ![]() ![]() |
I've been browsing this site for awhile, as I restore my '75 914. I'm mostly done, just working on finishing touches and some drivability issues. You guys have been a huge help but the details of my current issue has me stumped. Below is a summary of the issue:
1-With key OUT of the ignition the charging light is "ON" (IMG:style_emoticons/default/WTF.gif) 2- Key in on position, the charging light turns "OFF", oil light turns "ON" 3- Engine Running, charging light is "OFF" 4- Engine running, voltage regulator plugged in, voltage at battery reads 12.4 volts (not charging). 5- Engine running, voltage regulator unplugged & jumper between D+/DF voltage at battery reads 12.6-12.8 volts (still not really charging). 6-Occasionally, ignition key needs to be cycled several times before the starter is triggered to start the car (probably unrelated?) 7-Charging light turns "OFF" when alternator plug (specifically DF connection) is disconnected from relay board. Background info: New alternator 100 miles ago, belt tight, newer voltage regulator, new alternator wiring harness, newer ignition switch, transmission to trunk floor ground strap clean and tight. 20 miles ago, the charging system was working as it should. My theory: Alternator failure! But I don't want to throw parts at the situation if there are other clues in points 1-7 above. |
whiterabbit |
I also found items # 1 and 2 strange. At first I thought it was a failure in the ignition switch but that wouldn't explain the oil light turning "ON" as it should.
I didn't do any additional electrical work after the alternator was replaced nor did I disconnect the battery while the engine was running. I replaced the alternator last fall just before putting the car away for the winter. I drove the car about 80 miles over a couple weeks time. The day I parked it for long term winter storage, I shut off the engine, removed the key and noticed that the charge light was still on. I disconnected the battery and decided I'd deal with it in the spring...and here we are. I'll report back on the results of Spokes suggested test. ...and here's a photo of my 914. ![]() |
Lo-Fi Version | Time is now: 9th July 2025 - 08:15 PM |
