whiterabbit |
Rust Saver ![]() Group: Members Posts: 28 Joined: 10-March 20 From: Northwest Ohio Member No.: 24,014 Region Association: Upper MidWest ![]() ![]() |
I've been browsing this site for awhile, as I restore my '75 914. I'm mostly done, just working on finishing touches and some drivability issues. You guys have been a huge help but the details of my current issue has me stumped. Below is a summary of the issue:
1-With key OUT of the ignition the charging light is "ON" (IMG:style_emoticons/default/WTF.gif) 2- Key in on position, the charging light turns "OFF", oil light turns "ON" 3- Engine Running, charging light is "OFF" 4- Engine running, voltage regulator plugged in, voltage at battery reads 12.4 volts (not charging). 5- Engine running, voltage regulator unplugged & jumper between D+/DF voltage at battery reads 12.6-12.8 volts (still not really charging). 6-Occasionally, ignition key needs to be cycled several times before the starter is triggered to start the car (probably unrelated?) 7-Charging light turns "OFF" when alternator plug (specifically DF connection) is disconnected from relay board. Background info: New alternator 100 miles ago, belt tight, newer voltage regulator, new alternator wiring harness, newer ignition switch, transmission to trunk floor ground strap clean and tight. 20 miles ago, the charging system was working as it should. My theory: Alternator failure! But I don't want to throw parts at the situation if there are other clues in points 1-7 above. |
whiterabbit |
Agreed! I did confirm that removal of the alternator plug from the relay board turns the light "OFF", so the short must be in the alternator assembly.
+1 on alternator R&R being a PITA...on your back, working by feel only, contortionist arms/wrist/fingers...UGH! I'm dropping off a spare alternator to a local rebuilder today. The one that failed was a re-man bosch unit from AutohausAZ. |
Lo-Fi Version | Time is now: 9th July 2025 - 11:07 PM |
