> A creamsicle chassis, A diamond in the rough
Mark Henry
post Apr 1 2021, 09:20 PM
that's what I do!
I don't usually show customers cars but member Warren914 from Halifax nova Scotia has a 1975 914 that will be an interesting project. His teen has never run right in the 20 years he's owned it so it's in for a full engine restoration.
His 914 arrived from Halifax this week and at first glance it's nothing special, tired paint with lots of chips and dents. But a quick check shows it has little to no filler in the body.
Warren told me this crazy story about the PO being a aircraft mechanic for CP Air, a now defunct Canadian airline.
Yeah-yeah what ever dude (IMG:style_emoticons/default/rolleyes.gif)
sixnotfour
post Apr 3 2021, 08:45 AM
The Horror.. clack clack
Warren914
post Apr 3 2021, 11:05 AM
QUOTE(sixnotfour @ Apr 3 2021, 08:45 AM) *
It was running! Sounded like a really bad exhaust leak.
Mark Henry
post Apr 3 2021, 12:05 PM
that's what I do!
QUOTE(Warren914 @ Apr 3 2021, 01:05 PM) *
That was because the other side head was a smog head, the air pump is long gone and exhaust ports are plugged, but one of those plugs fell out.
The seat one could keep driving, it would never idle and when it finally failed the broken valve would likely pop a rod out the top of the case.
I've seen this trick done before.
Warren914
post Apr 3 2021, 12:16 PM
QUOTE(Mark Henry @ Apr 3 2021, 12:05 PM) *
It was running very poorly and I expect barely made it aboard the trailer. Surprising what will still move the car along. How does the other side look? Spark plugs were dripping with oil last time I checked them.
I'm looking forward to a solid (and clean) engine when you're finished.
Mark Henry   A creamsicle chassis   Apr 1 2021, 09:20 PM
Mark Henry   First order was to get the rockers off, which turn...   Apr 1 2021, 09:27 PM
JeffBowlsby   Explain the CS bit Mr. Henry.   Apr 1 2021, 09:27 PM
Mark Henry   Explain the CS bit Mr. Henry. All in good time ...   Apr 1 2021, 09:32 PM
Mark Henry   Typical couple pounds of sand that comes out of ro...   Apr 1 2021, 09:31 PM
Mark Henry   So we started to drop the engine and transmission....   Apr 1 2021, 09:37 PM
Mark Henry   :WTF: What is this colour I see peaking out unde...   Apr 1 2021, 09:41 PM
Mark Henry   What the fuch???   Apr 1 2021, 09:44 PM
Mark Henry   So no this isn't a creamsicle... but it has a ...   Apr 1 2021, 09:52 PM
Warren914   So no this isn't a creamsicle... but it has a...   Apr 2 2021, 06:43 AM
Mark Henry   The car wasn't red from the factory. PO did ...   Apr 2 2021, 08:35 AM
Mark Henry   Ohhh and the jack posts are bad so the longs must ...   Apr 1 2021, 09:59 PM
VegasRacer   WTH is it with all these bolts in the floors????...   Apr 1 2021, 10:16 PM
Mark Henry   But wait a minute?? :WTF: Holy Carp! Look a...   Apr 1 2021, 10:01 PM
Mark Henry   I think all the bolts are some sort of aircraft re...   Apr 1 2021, 10:26 PM
Mark Henry   :wttc:   Apr 2 2021, 07:27 AM
ValcoOscar   Same here :wttc: I'm looking forward to the ...   Apr 2 2021, 07:45 AM
Warren914   The car won't be complete this summer. Once Ma...   Apr 2 2021, 10:21 AM
Warren914   Same here :wttc: I'm looking forward to the...   Apr 15 2021, 07:41 AM
Mark Henry   It won't be done this time around, it will sti...   Apr 2 2021, 08:16 AM
mepstein   The floor bolts are really strange.   Apr 2 2021, 09:03 AM
Mark Henry   The floor bolts are really strange. They had m...   Apr 2 2021, 10:03 AM
Warren914   Tim bought the car and took it to Vancouver in 1...   Apr 2 2021, 10:36 AM
914werke   The floor bolts are really strange. original fl...   Apr 2 2021, 10:13 AM
Root_Werks   [quote name='Mark Henry' post='2904964' date='Apr...   Apr 2 2021, 10:31 AM
Mark Henry   The verdict is in on Warren's engine troubles,...   Apr 2 2021, 10:39 AM
Warren914   The dreaded dropped valve seat, #3 intake this ti...   Apr 2 2021, 11:09 AM
Mark Henry   Things are not torqued proper, if it didn't lo...   Apr 2 2021, 10:58 AM
Mark Henry   Yes but later I'm to greasy to be touching any...   Apr 2 2021, 11:33 AM
MM1   Thanks for sharing! I truly hope "we...   Apr 2 2021, 11:55 AM
BENBRO02   Thanks for sharing! I truly hope "we...   Apr 2 2021, 12:46 PM
930cabman   Thanks for sharing! I truly hope "we...   Apr 2 2021, 01:26 PM
Warren914   [quote name='BENBRO02' post='2904999' date='Apr 2...   Apr 2 2021, 02:31 PM
CptTripps   I'm planning to retire by 31 December 2022. Th...   Apr 3 2021, 02:43 AM
wonkipop   i reckon that car is pretty ace. been worked over ...   Apr 3 2021, 01:42 AM
930cabman   What percentage of our +/- 50 years old 914's ...   Apr 3 2021, 06:56 AM
Mark Henry   Dropped engine and the unfortunate dropped valve s...   Apr 3 2021, 08:10 AM
sixnotfour   The Horror.. clack clack   Apr 3 2021, 08:45 AM
Warren914   The Horror.. clack clack It was running! S...   Apr 3 2021, 11:05 AM
930cabman   The Horror.. clack clack It was running! ...   Apr 3 2021, 11:38 AM
Warren914   It was running! Sounded like a really bad ex...   Apr 3 2021, 12:25 PM
Mark Henry   The Horror.. clack clack It was running! ...   Apr 3 2021, 12:05 PM
Warren914   That was because the other side head was a smog ...   Apr 3 2021, 12:16 PM
Warren914   Two years since the last update. I'm getting m...   Apr 15 2023, 10:48 AM
mepstein   Two years since the last update. I'm getting ...   Apr 15 2023, 11:14 AM
Montreal914   :) perfect season timing! :driving: But......   Apr 15 2023, 11:19 AM
- Lo-Fi Version Time is now: 15th April 2026 - 08:05 PM
