> Throttle cable broken, Where the purchase new one (914 Rubber is out).
HansJan
post Mar 9 2021, 12:20 PM
Ok. It was my turn to break down.
The throttle cable broke.
I was able to crank up the idle and limp to work.
Looking to buy new cable, so I can get back on the road.
914Rubber is sold out. Where can I buy a new one (for carbureted car with X-bar linkage).
Auto Atlanta might have them, but with them you never know when to expect the parts.
HansJan
post Apr 3 2021, 11:21 PM
Now I have really done it.
This 'easy' throttle cable replacement became a major issue.
Not knowing if the Terry Cable (the one they send me, that does not have a sleeve around it for the section thats in the tunnel) I went to install it. Just to see if it would work.
Without the sleeve I assumed that the cable it not stiff enough, so I wanted to install a pull-rope. I tied a pull-rope to the end of the cable that Pelican Parts send me (the one where the threads broke upon install) and pulled it through the tube. At least that was the plan. It got stuck inside the tube. I guess the rope together with the end-fitting is too much to fit through the tube. (IMG:style_emoticons/default/headbang.gif)
Now I really do not know what to do. I removed the middle seat and tunnel cover. Then part of the center console and the shifter assembly. But I still cannot see the end of the tube.
Oh... Did I mention that the pull-rope broke..?
Please please help, before I do some more stupid stuff.
Does anyone here have a picture that shows how I can see and reach the end of the guide-tube? I'm just hoping that the end-fitting is still sticking out somewhat.
Alternatively I could pull much harder on the cable from the bulkhead. But changes are that it get worse.
HansJan   Throttle cable broken   Mar 9 2021, 12:20 PM
BillJ   you can try pelicanparts.com I bet they will have...   Mar 9 2021, 12:24 PM
Root_Werks   When you find a place that has some in stock, buy ...   Mar 9 2021, 12:44 PM
bbrock   I just ordered a custom length accelerator cable f...   Mar 9 2021, 01:27 PM
ClayPerrine   Call @partguy22 (Aaron) at Zims. 817-267-4451. He...   Mar 9 2021, 01:45 PM
HansJan   Finally I find the time to install the cable I bou...   Mar 20 2021, 08:38 PM
bdstone914   Finally I find the time to install the cable I bo...   Mar 21 2021, 08:57 AM
HansJan   What brand cable was it ? I like Gemo. I have hear...   Mar 21 2021, 09:58 AM
scottthephotog   Finally I find the time to install the cable I bo...   Mar 21 2021, 06:12 PM
HansJan   Ooof. I've had that happen. As Clay said, Zim...   Mar 21 2021, 07:28 PM
HansJan   Also found that the pedal is not resting on the pe...   Mar 21 2021, 10:00 AM
Mark Henry   Yeah that part can break if even slightly over tig...   Mar 21 2021, 10:26 AM
HansJan   Seems that this easy repair is becoming a challeng...   Mar 31 2021, 08:46 PM
Sycolyst   Following....same issue. I drilled out a bolt and...   Apr 1 2021, 04:57 AM
Olympic 914   Have you checked the Porsche dealers? That's ...   Apr 1 2021, 08:05 AM
HansJan   Now I have really done it. This 'easy' thr...   Apr 3 2021, 11:21 PM
ndfrigi   how about spending something like this and you can...   Apr 4 2021, 01:23 AM
Tdskip   Oh man, hate when this stuff snowballs.   Apr 4 2021, 06:07 AM
bbrock   I think I would try gently jerking the accelerator...   Apr 4 2021, 09:06 AM
Mikey914   Pretty sure I have most of the parts needed to fab...   Apr 4 2021, 09:10 AM
HansJan   Pretty sure I have most of the parts needed to fa...   Apr 4 2021, 11:53 AM
914werke   I just ordered a custom length accelerator cable ...   Apr 4 2021, 11:24 AM
HansJan   I just ordered a custom length accelerator cable...   Apr 4 2021, 11:52 AM
HansJan   Using brute force, I was able to pull the jammed c...   Apr 4 2021, 09:52 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:24 PM
