> Throttle cable broken, Where the purchase new one (914 Rubber is out).
HansJan
post Mar 9 2021, 12:20 PM
Ok. It was my turn to break down.
The throttle cable broke.
I was able to crank up the idle and limp to work.
Looking to buy new cable, so I can get back on the road.
914Rubber is sold out. Where can I buy a new one (for carbureted car with X-bar linkage).
Auto Atlanta might have them, but with them you never know when to expect the parts.
HansJan
post Apr 4 2021, 09:52 PM
Using brute force, I was able to pull the jammed cable (with pull-cord) out of the back.
The Terry-cable is installed. But I can hear and feel it rubbing against the inside if the tunnel-tube. It is not going to last very long.
Let's convince 914Rubber to start making these for us.
The one positive thing that comes out of all this is that 6" additional length is just right for carbureted (Hex-bar) cars.
HansJan   Throttle cable broken   Mar 9 2021, 12:20 PM
BillJ   you can try pelicanparts.com I bet they will have...   Mar 9 2021, 12:24 PM
Root_Werks   When you find a place that has some in stock, buy ...   Mar 9 2021, 12:44 PM
bbrock   I just ordered a custom length accelerator cable f...   Mar 9 2021, 01:27 PM
ClayPerrine   Call @partguy22 (Aaron) at Zims. 817-267-4451. He...   Mar 9 2021, 01:45 PM
HansJan   Finally I find the time to install the cable I bou...   Mar 20 2021, 08:38 PM
bdstone914   Finally I find the time to install the cable I bo...   Mar 21 2021, 08:57 AM
HansJan   What brand cable was it ? I like Gemo. I have hear...   Mar 21 2021, 09:58 AM
scottthephotog   Finally I find the time to install the cable I bo...   Mar 21 2021, 06:12 PM
HansJan   Ooof. I've had that happen. As Clay said, Zim...   Mar 21 2021, 07:28 PM
HansJan   Also found that the pedal is not resting on the pe...   Mar 21 2021, 10:00 AM
Mark Henry   Yeah that part can break if even slightly over tig...   Mar 21 2021, 10:26 AM
HansJan   Seems that this easy repair is becoming a challeng...   Mar 31 2021, 08:46 PM
Sycolyst   Following....same issue. I drilled out a bolt and...   Apr 1 2021, 04:57 AM
Olympic 914   Have you checked the Porsche dealers? That's ...   Apr 1 2021, 08:05 AM
HansJan   Now I have really done it. This 'easy' thr...   Apr 3 2021, 11:21 PM
ndfrigi   how about spending something like this and you can...   Apr 4 2021, 01:23 AM
Tdskip   Oh man, hate when this stuff snowballs.   Apr 4 2021, 06:07 AM
bbrock   I think I would try gently jerking the accelerator...   Apr 4 2021, 09:06 AM
Mikey914   Pretty sure I have most of the parts needed to fab...   Apr 4 2021, 09:10 AM
HansJan   Pretty sure I have most of the parts needed to fa...   Apr 4 2021, 11:53 AM
914werke   I just ordered a custom length accelerator cable ...   Apr 4 2021, 11:24 AM
HansJan   I just ordered a custom length accelerator cable...   Apr 4 2021, 11:52 AM
HansJan   Using brute force, I was able to pull the jammed c...   Apr 4 2021, 09:52 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:18 PM
