| BeatNavy |
Apr 6 2021, 08:51 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
I'm inching closer, ever closer at a glacial pace, to break down and learn how to paint. I'm probably going to buy a turbine HLVP setup soon. I think I've finally decided to take my car back to its original L60E, Irish Green.
Question: why can't I find a place that will mix this? I initially tried places in Maryland until I learned that one really can't buy anything other than water-based paint in Maryland. Ok, so I'm willing to drive to Delaware or Virginia. But I've called like 6 places, and while they can find L60E in their book, they don't seem to be able to mix it. I do have a place about and hour and a half away from me in VA that says he "probably" can mix it up. I'd like a little more confidence than "probably" before I take a 3 hour round trip. Totally new to this process, so I'm looking for ideas. |
| 76-914 |
Apr 6 2021, 04:23 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
My only experience with a Turbine HVLP was about 25 years ago so what I'm about to say may have been corrected. They seemed to work well for woodworkers spraying varnish and such but the turbine blows hot air and when spraying auto paint it would end up looking chalky unless you held the gun very close to the surface. Then the pattern was greatly reduced and runs were a problem. If you buy an 80 gal compressor and an HVLP gun you will always have that large compressor to use with many other tools afterwards. There are some Chinese made De Vilbess knock offs that work really well and are less than $100. Look for a gun that will accept different size tips and spend ~$25 on a Paint viscosity tester so you get the correct consistency when spraying. (IMG:style_emoticons/default/beerchug.gif)
BeatNavy Where to Source Paint Apr 6 2021, 08:51 AM
jd74914 There is a PPG dealer nearby who can mix paint wit... Apr 6 2021, 08:56 AM
Mikey914 True L60E probably has some items in it that you c... Apr 6 2021, 09:02 AM
Shivers I don't know if this will help but:
"1970... Apr 6 2021, 09:11 AM
jasons When I painted my car, I went to one of the best p... Apr 6 2021, 09:19 AM
roblav1 The PPG dealer in Suffolk, VA mixed my paint. I g... Apr 6 2021, 09:44 AM
roblav1 Also, the Black Widow HVLP gun from Harbor Freight... Apr 6 2021, 09:45 AM
BeatNavy Thanks for the suggestions. I did call the nation... Apr 6 2021, 10:01 AM
BeatNavy I called a couple of other shops in MD and VA toda... Apr 6 2021, 03:19 PM
914e
I called a couple of other shops in MD and VA tod... Apr 6 2021, 03:32 PM
roblav1 When I was in the PPG store in Suffolk, they showe... Apr 6 2021, 04:05 PM
BeatNavy Thanks, @914e and [b]@[url=http://www.914world.... Apr 6 2021, 04:21 PM
BeatNavy
My only experience with a Turbine HVLP was about ... Apr 6 2021, 04:36 PM
rudedude I just painted a 911 using a turbine and was quite... Apr 6 2021, 07:37 PM
mepstein Rob - Call me if I can help with any DE shops. We ... Apr 6 2021, 07:49 PM
wndsrfr Best paint I ever got was Glasurit...15 years ago ... Apr 6 2021, 07:57 PM
BeatNavy Thanks, Mark / John. Mark, I called two of the Ka... Apr 7 2021, 05:53 AM
mepstein When you think you found the right paint, buy a sm... Apr 7 2021, 07:28 AM
BeatNavy
When you think you found the right paint, buy a s... Apr 7 2021, 07:36 AM
BeatNavy @wndsrfr from the BASF website you posted I found... Apr 7 2021, 07:28 AM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 7 2021, 07:38 AM
BeatNavy Thanks, Mark, I appreciate the offer. I'll le... Apr 7 2021, 07:44 AM
bbrock I can't offer anything new here but will share... Apr 7 2021, 07:55 AM
StarBear
I can't offer anything new here but will shar... Apr 7 2021, 12:21 PM
BillJ
I can't offer anything new here but will shar... Apr 8 2021, 05:59 AM
bbrock
Did you happen to save the formulas that they pro... Apr 8 2021, 07:42 AM
BillJ
Did you happen to save the formulas that they pr... Apr 8 2021, 01:43 PM
mgarrison I found Ravenna Green at this site:
https://www.a... Apr 7 2021, 09:56 AM
BillC I've been getting the paint for the dapo-speci... Apr 7 2021, 11:46 AM
930cabman Our 356SC is factory Irish Green and has been spot... Apr 7 2021, 12:24 PM
worn I have had good luck with PPG paint. Expensive st... Apr 7 2021, 04:40 PM
BeatNavy Just pulled the trigger on one of these. It's... Apr 7 2021, 05:40 PM
worn
Just pulled the trigger on one of these. It... Apr 7 2021, 06:06 PM
jd74914
Just pulled the trigger on one of these. It... Apr 8 2021, 07:25 AM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Jun 14 2021, 06:46 PM
BeatNavy
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 15 2021, 06:56 AM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Jun 15 2021, 01:19 PM
BeatNavy
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 15 2021, 02:01 PM
Freezin 914 :popcorn: Apr 7 2021, 06:20 PM
930cabman Is anyone making the original synthol enamel singl... Jun 14 2021, 03:37 PM
Superhawk996 Orange peel is free all day long if you want it. ... Jun 14 2021, 03:57 PM
windforfun Try paintscratch.com. They matched my marathon bl... Jun 14 2021, 04:56 PM
Front yard mechanic Try TPC global / auto color library. mfg. code 6... Jun 14 2021, 09:09 PM
rjames Wahoo!
:Qarl: :headbanger: Jun 15 2021, 01:41 PM
930cabman Is anyone using single stage? as opposed to base/c... Jun 15 2021, 04:20 PM
crash914 Try Marty's auto paint in Baltimore/Rosedale.
... Jun 17 2021, 03:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:32 AM |
