| 911914 |
Dec 27 2004, 11:33 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 24-December 04 From: Vancouver, Washington Member No.: 3,334 |
I am sure this has been hashed out here many times before and I don't want to start another oil thread but I be a newbie. Car I just purchased was rebuilt about 20k ago ('74 2.o) and the records show 15-40 weight has been used since rebuild and at all services. Now is this not a heavy diesel weight oil? I use this weight in my BMW 535i as recommended from factory, but a small air cooled VW mill using this heavy weight? Doesn't sound right to me. Clue me in please. Oh, engine is dual Weber's and a Web cam.
Thanks. |
| Steve |
Dec 29 2004, 11:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
The higher the number the thicker the oil.
I remember reading that Castrol has foaming problems and some people don't recommend it. In Bruce Anderson's Porsche 911 Performance handbook he lists the following oils and does not list Castrol: Kendal, Quaker state, Valvoline and Pennzoil or Mobile One for synthetic. I'm running 15-50 Mobile One in my 3.2 and I'm planning on switching to regular 15W-40 because of new oil leaks. Can anyone recommend a good oil in this weight? How much more is Kendal versus Quaker State? I will have to see what's available at Costco. |
911914 Motor oil Dec 27 2004, 11:33 PM
markb I use 20/50 in the 914s & the Bus (2.4/6). Dec 28 2004, 12:23 AM
911914 Thanks Mark, I too use the 20-50 (Castrol) in my A... Dec 28 2004, 12:40 AM
ChrisReale 15-40 is prolly Shell Rotella, which is a good oil... Dec 28 2004, 04:20 AM
type11969 I use 5w-30 and have plenty of pressure all around... Dec 28 2004, 07:12 AM
911914 New twist to my oil question. Called the PO engin... Dec 28 2004, 01:18 PM
Root_Werks Woah you guys, you are all giving great advise, bu... Dec 28 2004, 01:30 PM
SirAndy Dec 28 2004, 01:32 PM
Rhodes71/914 I've always used 10-40 in all my VW aircooled ... Dec 28 2004, 01:54 PM
7391420 kendal straight 30 in winter, straight 50 in summ... Dec 28 2004, 02:04 PM
Cap'n Krusty <... Dec 28 2004, 03:06 PM
type11969 how can you say it is too thin if I have plenty of... Dec 28 2004, 03:23 PM
SirAndy htt... Dec 28 2004, 04:40 PM
ChrisReale Forget the weight, just make sure you use oil, per... Dec 28 2004, 11:46 PM
dlo914 20w50 / W = Winter NOT Weight ... Dec 29 2004, 12:42 AM
dlo914 use higher winter if your region is prone to very ... Dec 29 2004, 12:46 AM
Tom73 My understanding has always been that a
10w30
wi... Dec 29 2004, 09:56 AM
type11969 yeah, my understanding is the same as yours Tom. I... Dec 29 2004, 10:19 AM
rdauenhauer So what about the "newer car" spec 0-40 syn oils (... Dec 29 2004, 10:32 AM
type11969 The problem I have with mobil one in a t1 or a t4 ... Dec 29 2004, 11:21 AM
Steve According to Bruce Anderson in Tech notes II, this... Dec 29 2004, 11:41 AM
Aaron Cox larger number = thicker oil right?
50= THICK
10= ... Dec 29 2004, 11:45 AM
type11969 I seem to remember Jake stating that he had proble... Dec 29 2004, 12:26 PM
dlo914 http://www.914world.com/bbs... Dec 29 2004, 12:29 PM
Tom73 Dec 29 2004, 05:25 PM
Steve Dec 29 2004, 08:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:00 AM |
