> Where to Source Paint, What's the trick?
BeatNavy
post Apr 6 2021, 08:51 AM
I'm inching closer, ever closer at a glacial pace, to break down and learn how to paint. I'm probably going to buy a turbine HLVP setup soon. I think I've finally decided to take my car back to its original L60E, Irish Green.
Question: why can't I find a place that will mix this? I initially tried places in Maryland until I learned that one really can't buy anything other than water-based paint in Maryland. Ok, so I'm willing to drive to Delaware or Virginia. But I've called like 6 places, and while they can find L60E in their book, they don't seem to be able to mix it.
I do have a place about and hour and a half away from me in VA that says he "probably" can mix it up. I'd like a little more confidence than "probably" before I take a 3 hour round trip.
Totally new to this process, so I'm looking for ideas.
post Apr 7 2021, 07:28 AM
914-6 GT in waiting
When you think you found the right paint, buy a small amount of it and practice with your spray gun. Just like house paint, the color will often look different than it's supposed to but at least you will get practice and dial in your settings and technique.
I think Michael/Cairo's crew had to play around a bit to find the right green for his car.
I'm no expert on paint but I do know from buying it for the shop that there is a lot of variation. You need to look at actual spray out samples and not just what the book says it should look like. Different paint brands and even different quality lines within the brands will all look different.
BeatNavy
post Apr 7 2021, 07:36 AM
QUOTE(mepstein @ Apr 7 2021, 08:28 AM) *
Yes, good advice and that's my understanding as well. I will sample it on some scrap metal, but that's at least partially why I first want to do parts of the car that won't be seen (or seen much) like the rollbar.
BeatNavy   Where to Source Paint   Apr 6 2021, 08:51 AM
jd74914   There is a PPG dealer nearby who can mix paint wit...   Apr 6 2021, 08:56 AM
Mikey914   True L60E probably has some items in it that you c...   Apr 6 2021, 09:02 AM
Shivers   I don't know if this will help but: "1970...   Apr 6 2021, 09:11 AM
jasons   When I painted my car, I went to one of the best p...   Apr 6 2021, 09:19 AM
roblav1   The PPG dealer in Suffolk, VA mixed my paint. I g...   Apr 6 2021, 09:44 AM
roblav1   Also, the Black Widow HVLP gun from Harbor Freight...   Apr 6 2021, 09:45 AM
BeatNavy   Thanks for the suggestions. I did call the nation...   Apr 6 2021, 10:01 AM
BeatNavy   I called a couple of other shops in MD and VA toda...   Apr 6 2021, 03:19 PM
914e   I called a couple of other shops in MD and VA tod...   Apr 6 2021, 03:32 PM
roblav1   When I was in the PPG store in Suffolk, they showe...   Apr 6 2021, 04:05 PM
BeatNavy   Thanks, @914e and [b]@[url=http://www.914world....   Apr 6 2021, 04:21 PM
76-914   My only experience with a Turbine HVLP was about 2...   Apr 6 2021, 04:23 PM
BeatNavy   My only experience with a Turbine HVLP was about ...   Apr 6 2021, 04:36 PM
rudedude   I just painted a 911 using a turbine and was quite...   Apr 6 2021, 07:37 PM
mepstein   Rob - Call me if I can help with any DE shops. We ...   Apr 6 2021, 07:49 PM
wndsrfr   Best paint I ever got was Glasurit...15 years ago ...   Apr 6 2021, 07:57 PM
BeatNavy   Thanks, Mark / John. Mark, I called two of the Ka...   Apr 7 2021, 05:53 AM
mepstein   When you think you found the right paint, buy a sm...   Apr 7 2021, 07:28 AM
BeatNavy   When you think you found the right paint, buy a s...   Apr 7 2021, 07:36 AM
BeatNavy   @wndsrfr from the BASF website you posted I found...   Apr 7 2021, 07:28 AM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 7 2021, 07:38 AM
BeatNavy   Thanks, Mark, I appreciate the offer. I'll le...   Apr 7 2021, 07:44 AM
bbrock   I can't offer anything new here but will share...   Apr 7 2021, 07:55 AM
StarBear   I can't offer anything new here but will shar...   Apr 7 2021, 12:21 PM
BillJ   I can't offer anything new here but will shar...   Apr 8 2021, 05:59 AM
bbrock   Did you happen to save the formulas that they pro...   Apr 8 2021, 07:42 AM
BillJ   Did you happen to save the formulas that they pr...   Apr 8 2021, 01:43 PM
mgarrison   I found Ravenna Green at this site: https://www.a...   Apr 7 2021, 09:56 AM
BillC   I've been getting the paint for the dapo-speci...   Apr 7 2021, 11:46 AM
930cabman   Our 356SC is factory Irish Green and has been spot...   Apr 7 2021, 12:24 PM
worn   I have had good luck with PPG paint. Expensive st...   Apr 7 2021, 04:40 PM
BeatNavy   Just pulled the trigger on one of these. It's...   Apr 7 2021, 05:40 PM
worn   Just pulled the trigger on one of these. It...   Apr 7 2021, 06:06 PM
jd74914   Just pulled the trigger on one of these. It...   Apr 8 2021, 07:25 AM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Jun 14 2021, 06:46 PM
BeatNavy   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 15 2021, 06:56 AM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Jun 15 2021, 01:19 PM
BeatNavy   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 15 2021, 02:01 PM
Freezin 914   :popcorn:   Apr 7 2021, 06:20 PM
930cabman   Is anyone making the original synthol enamel singl...   Jun 14 2021, 03:37 PM
Superhawk996   Orange peel is free all day long if you want it. ...   Jun 14 2021, 03:57 PM
windforfun   Try paintscratch.com. They matched my marathon bl...   Jun 14 2021, 04:56 PM
Front yard mechanic   Try TPC global / auto color library. mfg. code 6...   Jun 14 2021, 09:09 PM
rjames   Wahoo! :Qarl: :headbanger:   Jun 15 2021, 01:41 PM
930cabman   Is anyone using single stage? as opposed to base/c...   Jun 15 2021, 04:20 PM
crash914   Try Marty's auto paint in Baltimore/Rosedale. ...   Jun 17 2021, 03:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:04 PM
