MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) ![]() ![]() ![]() ![]() |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
The GoWesty throttle body came like this, some kind of a cheap plastic cam printed from a 3d printer.
![]() To make this work, I bought a 2nd switch, and stacked it on top. Also got rid of the 3d printed cam, and had two new ones made. ![]() ![]() Lots of screwing around, but I'm hopeful that this setup will at least work as well as the original if not better. Bigger throttle plate, double sealed ball bearings, and the action is so much smoother than what I had. |
strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
Lo-Fi Version | Time is now: 20th June 2024 - 09:58 AM |
