> Easy way to install Master cylinder reservoir tubes
pcdarks
post Apr 7 2021, 06:58 PM
I was reading somewhere here about how difficult it is to get the tubes from the reservoir into the grommets on the master cylinder. I greased them up with caliper assembly lube and they slipped in as easy as a 50 year ol....well lets just say they went right in.
bkrantz
post Apr 7 2021, 07:43 PM
Assuming this is for a replacement MC, I think the easiest way is to detach the tubes from the reservoir, shove them down at least 6 inches, and install the tubes into the MC before mounting it to the bulkhead.
pcdarks   Easy way to install Master cylinder reservoir tubes   Apr 7 2021, 06:58 PM
mepstein   Did you include the metal washers?   Apr 7 2021, 07:11 PM
pcdarks   Did you include the metal washers? I'm confu...   Apr 7 2021, 07:20 PM
infraredcalvin   Did you include the metal washers? I'm conf...   Apr 7 2021, 07:25 PM
pcdarks   [quote name='pcdarks' post='2906394' date='Apr 7 ...   Apr 7 2021, 07:45 PM
pcdarks   There are no washers. The incoming lines are flare...   Apr 7 2021, 07:16 PM
mepstein   There are no washers. The incoming lines are flar...   Apr 7 2021, 07:34 PM
JLance67   There are no washers. The incoming lines are fla...   Oct 24 2022, 08:10 AM
bdstone914   [quote name='pcdarks' post='2906393' date='Apr 7...   Oct 24 2022, 08:37 AM
JLance67   [quote name='JLance67' post='3037465' date='Oct 2...   Oct 27 2022, 12:52 AM
Superhawk996   It's like they slowly apply until they compl...   Oct 27 2022, 06:31 AM
infraredcalvin   I’ve done this several times and have struggled ...   Apr 7 2021, 07:23 PM
bkrantz   Assuming this is for a replacement MC, I think the...   Apr 7 2021, 07:43 PM
pcdarks   Assuming this is for a replacement MC, I think th...   Apr 7 2021, 07:46 PM
bbrock   I also used brake assembly lube and pulled them on...   Apr 7 2021, 07:53 PM
pcdarks   I also used brake assembly lube and pulled them o...   Apr 7 2021, 08:11 PM
bbrock   [quote name='bbrock' post='2906407' date='Apr 7 2...   Apr 7 2021, 08:32 PM
mepstein   I also used brake assembly lube and pulled them ...   Apr 7 2021, 08:43 PM
Chris914n6   My new 914rubber M/C leaks too. The tubes seem a l...   Oct 3 2022, 01:56 PM
Morrie   My new 914rubber M/C leaks too. The tubes seem a ...   Oct 3 2022, 02:22 PM
914werke   :popcorn:   Apr 7 2021, 08:16 PM
bbrock   Oh, and I'm a huge fan of 914Rubber and have b...   Apr 7 2021, 08:53 PM
Morrie   Oh, and I'm a huge fan of 914Rubber and have ...   Oct 3 2022, 12:19 PM
bbrock   Oh, and I'm a huge fan of 914Rubber and have...   Oct 3 2022, 01:04 PM
Morrie   Hi Brent, I realize this is a super old post. A...   Oct 3 2022, 02:18 PM
IronHillRestorations   If the grommets went in really easily, the washers...   Apr 7 2021, 09:14 PM
pcdarks   If the grommets went in really easily, the washer...   Apr 9 2021, 04:49 PM
wysri9   Another thread that maybe saved my life.....I need...   Apr 7 2021, 10:27 PM
brant   hopefully there are metal washers under your newly...   Apr 8 2021, 08:31 AM
Steve   I just went through this. The rubber bushings wer...   Apr 8 2021, 08:49 AM
mgphoto   When attaching the rubber grommets after installin...   Oct 3 2022, 02:02 PM
willieg   Before I bought a 19 mm master cylinder from 914Ru...   Oct 3 2022, 03:02 PM
Morrie   Before I bought a 19 mm master cylinder from 914R...   Oct 3 2022, 03:05 PM
- Lo-Fi Version Time is now: 15th September 2026 - 04:25 PM
