| partwerks |
Feb 7 2021, 05:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
For sale: Parts lot
All used parts. Cash if local pickup, or paypal if being shipped. Shipping on top of stated price. 1. Relay board-came off of a running car, but has been sitting out in the elements for about 3 months, but very little moisture during those months. $42.00 2. Front hood hinges & springs-$41.00 3. Rear deck lid hinges-$20.00 4. Trunk torsion bars & clamps-$25.00 5. Window crank-$1.00 6. Hood release cable (no plastic tube) $25.00 7. Trunk light-$5.00 8. Relay board cover-has cut/crack on top, and a piece of corner broke off-$1.00 Knob, and bolt are SOLD. 9. Battery hold down clamp-$2.00 10. Front targa latches-one has a good handle, but bent hook, and the other one has a cracked handle, but good hook. Can make one good handle out of them both. $18.00 11. Front lower hood latch-$31.00 12. Used 200# springs-$40.00-SOLD 13. Dog bones, two-$10.00-SOLD 14. Clutch stop-$4.00-SOLD 15. Fuse box-$9.00 16. Fresh air vent tube grommets (pair) $5.00 17. Brake reservoir-$4.00-SOLD 18. Tripometer cable-$15.00-SOLD 19. Window channel sealing rails-one rail has two holes that are over sized-$15.00-Sold 20. Driver side vertical rollbar pad-$10.00-SOLD 21. Glove box locks (2) A bit rough around the front. One is complete, the other isn't-$20.00-Sold 22. Trans ground cable-$2.00-SOLD 23. Windshield pillar pads-has some material missing in the corners-$30.00-SOLD 24. L defroster duct-has inner tab broken off-$10.00 25. Control box pieces-Control box has some metal bracket parts broken off sides. Otherwise all have the tabs intact-$22.00 26. Clutch cable bracket w/bushing-$5.00 27. Clutch cable clevis-$5.00-SOLD 28. Pedal board hold down clamp (Pyramid shaped) $1.00-SOLD 29. Fuel pump bracket-$5.00-SOLD 30. After market rear swaybar-$50.00-SOLD 31. Steering column. Missing small screws for ignition switch retainer bezel around ignition lock on the front. No key. $114.00 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Medtner3 |
Apr 9 2021, 09:00 PM
Member ![]() ![]() Group: Members Posts: 191 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
any chance you have another relay board cover with nut/bolt
partwerks FS: Parts lot Feb 7 2021, 05:45 PM
Literati914 I'm interested in the aftermarket rear sway ba... Feb 7 2021, 05:57 PM
partwerks
I'm interested in the aftermarket rear sway b... Feb 7 2021, 06:04 PM
frostyf Couldn't see the a frame pads:
And keen to ... Feb 7 2021, 06:03 PM
partwerks
And keen to... Feb 7 2021, 06:25 PM
ndfrigi edited: since someone already ahead of me for #23
Literati914 .. besides the rear sway bar(30), I'd also lik... Feb 7 2021, 06:05 PM
partwerks
.. besides the rear sway bar(30), I'd also li... Feb 7 2021, 06:15 PM
cork i'll take the ground strap and dog bones, plea... Feb 8 2021, 08:26 AM
partwerks Bump Feb 11 2021, 07:19 PM
StarBear I’ll take #8 cover with post and knob. Will pm w... Feb 11 2021, 07:41 PM
partwerks Bump Feb 17 2021, 07:56 PM
ClayPerrine Just a note to whomever bought the rear sway bar. ... Feb 18 2021, 07:24 AM
B2524 Ill take the 200lbs springs
PM PP info and total
S... Feb 18 2021, 07:31 AM
rgb91424 I would like the clutch stop for pedal board #14 a... Feb 19 2021, 04:25 PM
partwerks Bump Feb 23 2021, 09:02 PM
partwerks Bump Mar 14 2021, 07:54 PM
partwerks Bump Apr 7 2021, 06:13 PM
mgp4591 PM sent. Apr 7 2021, 08:38 PM
56kabrio
PM sent.
I'd like the a pillar pads and th... Apr 8 2021, 12:27 AM
partwerks
any chance you have another relay board cover wit... Apr 9 2021, 09:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th October 2026 - 08:19 PM |
