Web cam solid lifter failure? |
mate914 |
Apr 11 2021, 09:02 AM
Matt Group: Members Posts: 753 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
As I was recently doing a jug and slug transfer on my 2056. As I rotated the engine one of the lifters slid out and landed in the box. When I picked the lifter up it appeared to have come apart, I push the part back down in. Are solid lifters empty in the middle, no springs or ball like the hydraulic?
1. Should they all be replaced? 2. I have a brand new set of CB performance solid lifters, will they work if same spects? 3. Should I just replace that one. 4. I kind of wanted to show up for Carlisle in a Porsche.... I have faith I can accomplish this. Especially with all the knowledge on this 914 world. Matt |
Mark Henry |
Apr 11 2021, 09:38 AM
Some are solid, some are two piece, some 2 piece have a c-clip, some have a lube hole, some don't...
Simple test to see if they're worn: New or good condition the face should be slightly convex. Place two lifters face to face and hold them up to a light. If good you should be able to see light on the outer edges. No light and IMO they're done. The lifter in question just put it back together, it doesn't need a clip once installed the loose part is trapped and not an issue. -Using new lifters on an old cam is a crap shoot, it will either work or the cam will go flat. -If the old lifters pass the test above use them. -Don't replace just one, replace them all. -Keep used lifters in order. |
mate914 |
Apr 11 2021, 10:19 AM
Some are solid, some are two piece, some 2 piece have a c-clip, some have a lube hole, some don't... Simple test to see if they're worn: New or good condition the face should be slightly convex. Place two lifters face to face and hold them up to a light. If good you should be able to see light on the outer edges. no light and IMO they're done. The lifter in question just put it back together, it doesn't need a clip once installed the loose part is trapped and not an issue. -Using new lifters on an old cam is a crap shoot, it will either work or the cam will go flat. -If the old lifters pass the test above use them. -Don't replace just one, replace them all. -Keep used lifters in order. That’s what I was thinking. It just feels better when someone else agrees with you. Matt |
Lo-Fi Version | Time is now: 1st June 2024 - 04:10 PM |
