Timing 73 2.0L D-jet, Help |
steuspeed |
Apr 11 2021, 06:48 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
In pursuit of hunting idle, I have done the following. New plugs and wires. All new vacuum lines. Reset the ECU to factory notch on the knob. With a mirror, I found two straight notches on the back edge of the fan. The first one lined up with the #1 plug on the distributer and the dizzy notch mark. I believe that is TDC? It was (red) so I marked red on the front edge of the fan where I can see it through the hole with my timing light. The second one ~4 blades further (no color) I marked yellow line on the front edge. Removed both vac lines from the dizzy. Run the engine up to about 2K and I can get the red to line up with the notch. As the RPM goes higher it walks toward the passenger side out of sight. Pertronix rotor no points.
Is seems to me the my yellow line should be lining up as per Hanes manual. What am I doing wrong? EDIT: Okay, so TDC should not be the red, but the unpainted clear mark. The red is the 27 BTDC timing mark. |
steuspeed |
Apr 13 2021, 11:39 PM
Okay, so I pulled the vac lines and plugged them. Turned the ECU knob to full rich. I can set the timing to the red mark like idle to 2K, then it move off to the right as I rev higher. The car starts on key turn. It idles high then comes down after about 1min, so air valve is closing proper. I tested it off car as well. It runs with a little buck/kick at low speeds. It's just not smooth. Get on it, and she goes pretty good. Hunting idle is still there. Inconsistent off throttle to idle speed. Any ideas?
I orders the MPS tune kit from Tangerine, so I will try and set that proper when it gets here. Mine has been tampered with by PO. Should I swap ECUs? or Coils? Switch to stock point? |
DRPHIL914 |
Apr 14 2021, 08:16 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Okay, so I pulled the vac lines and plugged them. Turned the ECU knob to full rich. I can set the timing to the red mark like idle to 2K, then it move off to the right as I rev higher. The car starts on key turn. It idles high then comes down after about 1min, so air valve is closing proper. I tested it off car as well. It runs with a little buck/kick at low speeds. It's just not smooth. Get on it, and she goes pretty good. Hunting idle is still there. Inconsistent off throttle to idle speed. Any ideas? I orders the MPS tune kit from Tangerine, so I will try and set that proper when it gets here. Mine has been tampered with by PO. Should I swap ECUs? or Coils? Switch to stock point? if hunting idle is still present you have a vac leak somewhere still OR the MPS is tuned too lean, this was my case with a rebuilt MPS not tuned correctly! this is why i installed a AF meter and O2 sensor in my Triad exhaust, you really cant tune that well without it, you can probably get close by rechecking plugs and just by feeling the idle change. - you will need the instructions of tuning the MPS if you do the rebuild. -https://members.rennlist.com/pbanders/DJetParts.htm Phil |
steuspeed |
Apr 14 2021, 02:55 PM
-https://members.rennlist.com/pbanders/DJetParts.htm Phil Once the AAR valve closes the engine idle drops from 1600rpm running smooth down to 300 and hunts 300-800. I cannot get the idle higher with the idle screw all the way out. If the hunt swing drops low enough it dies. I took out the MPS and it is part # 0 028 100 015 which does not match up with pbanders doc. The MPS in my 74 Outlaw is 0 028 100 001 which is another mystery. They should be ...037 and .. 043 respectively. EDIT: ...015 MPS in this car is for Volvo 1800, 160 and 140 71-74 ... 001 MPS in my 74 Outlaw is for VW Type 3 68-69 early style with one screw and no full load diaphragm. |
Lo-Fi Version | Time is now: 4th June 2024 - 09:42 AM |
