> 40 or 44 IDF Webers, size matters
930cabman
post Apr 14 2021, 05:00 PM
We are converting a stock 2 liter 4 cyl from D jet to Webers. My gut is telling me a 40 IDF with 32mm venturis is the correct starting point. I am considering purchase of a complete set of 44 IDF's, but are unable to locate 32 mm venturis. Assuming 32MM venturis can be found are 44 IDF"s too large for a stock 2 liter?
thank you
johnhora
post Apr 14 2021, 05:38 PM
930cabman...
what's wrong with the stock D-Jet?
have you tried to get it to work?
If converting a stock engine to carbs use 40IDFs since no change to cam.
930cabman
post Apr 14 2021, 06:06 PM
QUOTE(johnhora @ Apr 14 2021, 05:38 PM) *
930cabman...
Several years ago I came upon a low mileage rust free Alfa spider (flood car), after rebuilding pretty much the entire car, the D jet stumped me with it's sensors, ECU and a million electrical connections. I found a set of Weber40 DCOE's and never looked back. If/when a FI system is reasonably new and working I would service it, but working from a basket case, no way. Tooo many variables
930cabman   40 or 44 IDF Webers   Apr 14 2021, 05:00 PM
nditiz1   40 IDFs are best, but 44s will work if you choke t...   Apr 14 2021, 05:11 PM
barefoot   Question: is the diameter air the manifold interf...   Apr 14 2021, 05:17 PM
johnhora   930cabman... what's wrong with the stock D-Je...   Apr 14 2021, 05:38 PM
930cabman   930cabman... what's wrong with the stock D-J...   Apr 14 2021, 06:06 PM
brant   930cabman... what's wrong with the stock D-...   Apr 14 2021, 09:01 PM
930cabman   [quote name='930cabman' post='2908097' date='Apr ...   Apr 15 2021, 05:02 AM
Superhawk996   When operating correctly the Bosch system is far ...   Apr 15 2021, 05:42 AM
brant   1985 Alfa spider, maybe it was L jet, but very si...   Apr 15 2021, 08:58 AM
roblav1   At what what RPM is max HP? I'll take a swag ...   Apr 14 2021, 06:15 PM
930cabman   This is a stock 2 liter 4 cylinder engine. my gut ...   Apr 14 2021, 06:19 PM
roblav1   My 5800 rpm swag was off. My 914 spec says max hp...   Apr 14 2021, 06:27 PM
930cabman   My 5800 rpm swag was off. My 914 spec says max h...   Apr 14 2021, 06:40 PM
type2man   I would run 44 Webers. Personally I run 45 dells o...   Apr 14 2021, 06:36 PM
IronHillRestorations   You want 40's. With that engine the vacuum si...   Apr 14 2021, 07:11 PM
Root_Werks   You want 40's. With that engine the vacuum s...   Apr 15 2021, 09:29 AM
johnhora   OK so you have: Stock 2.0L type 4 with stock FI ca...   Apr 14 2021, 07:20 PM
johnhora   CB Performance's Bob Tomlinson's' book...   Apr 14 2021, 07:29 PM
930cabman   For me, it comes down to simple. Bolt on carbs, ...   Apr 15 2021, 05:46 AM
nditiz1   Simplicity for me too. I worked with the black ma...   Apr 15 2021, 06:11 AM
VaccaRabite   When I had my 2056 carbed I tried 44s and 40s. Th...   Apr 15 2021, 07:02 AM
930cabman   When I had my 2056 carbed I tried 44s and 40s. T...   Apr 15 2021, 07:27 AM
Racer   I ran 40's on a "stock" 1.7 and the ...   Apr 15 2021, 07:50 AM
Tdskip   For 90% of your driving throttle response matters ...   Apr 15 2021, 08:26 AM
ClayPerrine   I am on the side of Fuel Injection. I have run ...   Apr 15 2021, 12:19 PM
930cabman   It's looking like D jet might be winning. Fi...   Apr 15 2021, 12:49 PM
930cabman   I committed to D jet, sending the ECU to Module Ex...   Apr 16 2021, 01:08 PM
ClayPerrine   I committed to D jet, sending the ECU to Module E...   Apr 16 2021, 01:11 PM
930cabman   I committed to D jet, sending the ECU to Module ...   Apr 16 2021, 03:08 PM
bbrock   I committed to D jet, sending the ECU to Module E...   Apr 16 2021, 01:52 PM
Superhawk996   I committed to D jet, sending the ECU to Module E...   Apr 17 2021, 08:13 AM
bbrock   I've gotten the impression from reading variou...   Apr 17 2021, 08:36 AM
Superhawk996   I've gotten the impression from reading vario...   Apr 17 2021, 08:52 AM
930cabman   Yes, I have gathered the same, these rarely fail, ...   Apr 17 2021, 01:05 PM
stownsen914   I didn't read the whole thread, but my experie...   Apr 17 2021, 04:48 PM
930cabman   I didn't read the whole thread, but my experi...   Apr 17 2021, 05:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:20 PM
