| 930cabman |
Apr 14 2021, 05:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
We are converting a stock 2 liter 4 cyl from D jet to Webers. My gut is telling me a 40 IDF with 32mm venturis is the correct starting point. I am considering purchase of a complete set of 44 IDF's, but are unable to locate 32 mm venturis. Assuming 32MM venturis can be found are 44 IDF"s too large for a stock 2 liter?
thank you |
| type2man |
Apr 14 2021, 06:36 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I would run 44 Webers. Personally I run 45 dells on a 2.0 with a cam and headers and have no issues. Dells are much better.
930cabman 40 or 44 IDF Webers Apr 14 2021, 05:00 PM
nditiz1 40 IDFs are best, but 44s will work if you choke t... Apr 14 2021, 05:11 PM
barefoot Question: is the diameter air the manifold interf... Apr 14 2021, 05:17 PM
johnhora 930cabman...
what's wrong with the stock D-Je... Apr 14 2021, 05:38 PM
930cabman
930cabman...
what's wrong with the stock D-J... Apr 14 2021, 06:06 PM
brant
930cabman...
what's wrong with the stock D-... Apr 14 2021, 09:01 PM
930cabman
[quote name='930cabman' post='2908097' date='Apr ... Apr 15 2021, 05:02 AM
Superhawk996
When operating correctly the Bosch system is far ... Apr 15 2021, 05:42 AM
brant
1985 Alfa spider, maybe it was L jet, but very si... Apr 15 2021, 08:58 AM
roblav1 At what what RPM is max HP? I'll take a swag ... Apr 14 2021, 06:15 PM
930cabman This is a stock 2 liter 4 cylinder engine. my gut ... Apr 14 2021, 06:19 PM
roblav1 My 5800 rpm swag was off. My 914 spec says max hp... Apr 14 2021, 06:27 PM
930cabman
My 5800 rpm swag was off. My 914 spec says max h... Apr 14 2021, 06:40 PM
IronHillRestorations You want 40's. With that engine the vacuum si... Apr 14 2021, 07:11 PM
Root_Werks
You want 40's. With that engine the vacuum s... Apr 15 2021, 09:29 AM
johnhora OK so you have:
Stock 2.0L type 4 with stock FI ca... Apr 14 2021, 07:20 PM
johnhora CB Performance's Bob Tomlinson's' book... Apr 14 2021, 07:29 PM
930cabman For me, it comes down to simple.
Bolt on carbs, ... Apr 15 2021, 05:46 AM
nditiz1 Simplicity for me too. I worked with the black ma... Apr 15 2021, 06:11 AM
VaccaRabite When I had my 2056 carbed I tried 44s and 40s.
Th... Apr 15 2021, 07:02 AM
930cabman
T... Apr 15 2021, 07:27 AM
Racer I ran 40's on a "stock" 1.7 and the ... Apr 15 2021, 07:50 AM
Tdskip For 90% of your driving throttle response matters ... Apr 15 2021, 08:26 AM
ClayPerrine I am on the side of Fuel Injection.
I have run ... Apr 15 2021, 12:19 PM
930cabman It's looking like D jet might be winning.
Fi... Apr 15 2021, 12:49 PM
930cabman I committed to D jet, sending the ECU to Module Ex... Apr 16 2021, 01:08 PM
ClayPerrine
I committed to D jet, sending the ECU to Module E... Apr 16 2021, 01:11 PM
930cabman
I committed to D jet, sending the ECU to Module ... Apr 16 2021, 03:08 PM
bbrock
I committed to D jet, sending the ECU to Module E... Apr 16 2021, 01:52 PM
Superhawk996
I committed to D jet, sending the ECU to Module E... Apr 17 2021, 08:13 AM
bbrock I've gotten the impression from reading variou... Apr 17 2021, 08:36 AM
Superhawk996
I've gotten the impression from reading vario... Apr 17 2021, 08:52 AM
930cabman Yes, I have gathered the same, these rarely fail, ... Apr 17 2021, 01:05 PM
stownsen914 I didn't read the whole thread, but my experie... Apr 17 2021, 04:48 PM
930cabman
I didn't read the whole thread, but my experi... Apr 17 2021, 05:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:19 PM |
