Heat exchangers, Restoration Design vs SSI |
Warren914 |
Apr 15 2021, 05:03 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I'm planning an exhaust refit on my '75 914. Any thoughts on stainless steel heat exchangers from Restoration Design vs those from SSI? Extra bits and pieces will be needed...
https://www.restoration-design.com/store/product/PP033 |
Racer |
Apr 15 2021, 05:25 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
iirc, the muffler and hangers for a 1.7/1.8 are different than a 2.0. Are you starting with a 75 1.8 or 2.0? If a 1.8, you would need to change more than just the heat exchangers to get it to all fit.
Warren914 |
Apr 15 2021, 05:40 AM
iirc, the muffler and hangers for a 1.7/1.8 are different than a 2.0. Are you starting with a 75 1.8 or 2.0? If a 1.8, you would need to change more than just the heat exchangers to get it to all fit. '75 2.0 liter with original exhaust system. I'm aware other parts are needed to make it all fit but don't have a list yet. The heat exchangers will likely be the largest part of the expense. |
bdstone914 |
Apr 15 2021, 11:34 AM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
iirc, the muffler and hangers for a 1.7/1.8 are different than a 2.0. Are you starting with a 75 1.8 or 2.0? If a 1.8, you would need to change more than just the heat exchangers to get it to all fit. '75 2.0 liter with original exhaust system. I'm aware other parts are needed to make it all fit but don't have a list yet. The heat exchangers will likely be the largest part of the expense. @Warren914 What you will need is: 1. left and right J tubes 2. left and right S branches with attaching brackets 3. Muffler bracket to match the muffler. 4. left and right warm air guides I have all but 4 that are cleaned and powder coated. Let me know if you are interested. |
Tom_T |
Apr 15 2021, 12:14 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
What you will need is: 1. left and right J tubes 2. left and right S branches with attaching brackets 3. Muffler bracket to match the muffler. 4. left and right warm air guides I have all but 4 that are cleaned and powder coated. Let me know if you are interested. Bruce - while I know that you have parts to sell - he may not need to replace all of those on his 2.0 - & can just get them cleaned up & PC'ed up in Nova Scotia. Since it's a 2.0 Warren - you should already have #3 the 2.0 Muffler Bracket, as well as the other 3 tubes & guides - so check your own parts for condition. If not nice or restorable - or if you don't want to bother with restoring yours - then Bruce is a good option for turn-key resto parts. You can also find SS J-tubes out there FS if you want to also keep that part attaching to the new SS-HEs in SS too. Other than the non-stock muffler - Rich's/914Werke is a good representation of the full set-up. However - if you are going to resto your own parts &/or get some new ones, then the ole "while I'm in there" kicks in, & you'll probably end up wanting to also restore & PC or paint the rest of the engine tins too. (IMG:style_emoticons/default/blink.gif) The good thing is that you'll probably never need to replace the SS HEs in your lifetime, nor in your kid's, nor .... you get the idea! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 6th June 2024 - 03:57 AM |
