| john77 |
Feb 13 2021, 01:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California
While I have the arches cut for the flares I figured it was a good time to strip the wheel wells to bare metal, fix anything I find, and reseal them. I’ve completed the fronts, but just started stripping the rears yesterday and have some questions.
What’s the best way to reseal/rustproof the section above the rear light housing? I’ve stripped a lot of 1970’s German rubberized seam sealer in my time but was surprises to find that section was filled with what looks like some kind of expanding foam. The area is obviously a crud catcher, so I’m wondering the best way to seal it back up? Seam sealer? Or is there some other product I should fill the void where the foam was first? https://photos.app.goo.gl/2RYXDYXEVmRorirE9 The other section I’m wondering about is in the front of the well where the sail panel meets the quarter panel (the L shaped section coming down into the wheel well). It seems odd that this was so open - is it supposed to be covered in seam sealer? I’ve scraped some debris out of it, but would love some advice on what to do with it when I paint/reseal everything. https://photos.app.goo.gl/K2gqHAMPtzvMgiMB7 |
| mlindner |
Apr 18 2021, 07:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Sorry John missed your question. Its Polyethene rolls 1/8 this used for splinters and air dams from Speedway Motors. Easy to cut, heat and bend. One 25 foot rolls does all four fenders. I did send my templates to Ben (mb911) for his 914-6, maybe he's making them. Mark
| john77 |
Apr 19 2021, 02:31 PM
Thanks @mlindner
I definitely plan on doing this. I've stripped all four wheel wells now have three of the flares finished and the insides coated with POR15. Once the fourth is done (hopefully 2 weeks from now) I'm going to scuff all the POR15 and spray them all with raptor bedliner and finish off with your wheel well liner idea. Do your front wheels rub at all on full lock? Just pushing the car around to move it I've noticed they start to feel "egg-shaped" near full lock. not sure if it's from rubbing or something else, the old fronts were set up with pretty aggressive camber to fit the 16x7s so i may need to readjust the front suspension. Sorry John missed your question. Its Polyethene rolls 1/8 this used for splinters and air dams from Speedway Motors. Easy to cut, heat and bend. One 25 foot rolls does all four fenders. I did send my templates to Ben (mb911) for his 914-6, maybe he's making them. Mark |
john77 Rust proofing rear wheel wells Feb 13 2021, 01:10 PM
Cairo94507 I would clean out all of that foam filler junk and... Feb 13 2021, 01:27 PM
john77
I would clean out all of that foam filler junk an... Feb 13 2021, 01:46 PM
Cairo94507 Can you post a picture the area you are referencin... Feb 13 2021, 03:35 PM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Feb 14 2021, 02:20 AM
bbrock I've been mulling what to do with that area fo... Feb 13 2021, 03:38 PM
john77 I have nothing against what the factory did, it se... Feb 13 2021, 04:10 PM
bbrock
I have nothing against what the factory did, it s... Feb 13 2021, 08:25 PM
Jamie
I have nothing against what the factory did, it ... Feb 13 2021, 08:40 PM
bbrock
[quote name='bbrock' post='2891117' date='Feb 13 ... Feb 13 2021, 08:49 PM
john77 It just dawned on me that maybe I could use cavity... Feb 14 2021, 02:24 AM
mlindner On mine John, lots of cleaning, some painting and ... Feb 13 2021, 04:36 PM
john77 @[url=http://www.914world.com/bbs2/index.php?showu... Feb 14 2021, 02:26 AM
burton73 What do you think of fender liners?
My 86 928 has... Feb 13 2021, 07:08 PM
bkrantz I dug out all the original foam on both sides from... Feb 13 2021, 08:34 PM
raynekat On my restoration/build, we dug all that foam out ... Feb 13 2021, 10:06 PM
bbrock
On my restoration/build, we dug all that foam out... Feb 13 2021, 11:22 PM
bkrantz
On my restoration/build, we dug all that foam out... Apr 18 2021, 08:59 PM
Cairo94507 @john77 - I would seal that up the best way you c... Feb 14 2021, 08:50 AM
bbrock
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 14 2021, 12:25 PM
john77 Thanks Brent.
I ordered some raptor spray-on bedl... Feb 15 2021, 10:49 AM
mate914 I removed all seam sealer and foam. Then coal blas... Feb 14 2021, 09:05 AM
Geezer914 I second the use of bed liner. I undercoated the ... Feb 14 2021, 09:07 AM
930cabman I plan on removing the asphalt based undercoating ... Feb 14 2021, 04:30 PM
Mikey914 We actually make these as a kit. Utilizing HDPE as... Apr 18 2021, 07:37 AM
mb911 I made my own liners and happy with them so far. Apr 19 2021, 06:41 AM
mlindner John77, if you'd like I can send you a paper t... Apr 20 2021, 04:18 AM
john77 That would be super helpful, thanks Mark!
Jo... Apr 20 2021, 12:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:31 AM |
