> Rust proofing rear wheel wells, I have questions
john77
post Feb 13 2021, 01:10 PM
While I have the arches cut for the flares I figured it was a good time to strip the wheel wells to bare metal, fix anything I find, and reseal them. I’ve completed the fronts, but just started stripping the rears yesterday and have some questions.
What’s the best way to reseal/rustproof the section above the rear light housing?
I’ve stripped a lot of 1970’s German rubberized seam sealer in my time but was surprises to find that section was filled with what looks like some kind of expanding foam. The area is obviously a crud catcher, so I’m wondering the best way to seal it back up? Seam sealer? Or is there some other product I should fill the void where the foam was first?
https://photos.app.goo.gl/2RYXDYXEVmRorirE9
The other section I’m wondering about is in the front of the well where the sail panel meets the quarter panel (the L shaped section coming down into the wheel well).
It seems odd that this was so open - is it supposed to be covered in seam sealer?
I’ve scraped some debris out of it, but would love some advice on what to do with it when I paint/reseal everything.
https://photos.app.goo.gl/K2gqHAMPtzvMgiMB7
mlindner
post Apr 20 2021, 04:18 AM
John77, if you'd like I can send you a paper template of each wheel well as a start point. With flares all liners will be a little different. I'm also going to add a rubber cowl seal around the edges to keep all water out. Mark
john77   Rust proofing rear wheel wells   Feb 13 2021, 01:10 PM
Cairo94507   I would clean out all of that foam filler junk and...   Feb 13 2021, 01:27 PM
john77   I would clean out all of that foam filler junk an...   Feb 13 2021, 01:46 PM
Cairo94507   Can you post a picture the area you are referencin...   Feb 13 2021, 03:35 PM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Feb 14 2021, 02:20 AM
bbrock   I've been mulling what to do with that area fo...   Feb 13 2021, 03:38 PM
john77   I have nothing against what the factory did, it se...   Feb 13 2021, 04:10 PM
bbrock   I have nothing against what the factory did, it s...   Feb 13 2021, 08:25 PM
Jamie   I have nothing against what the factory did, it ...   Feb 13 2021, 08:40 PM
bbrock   [quote name='bbrock' post='2891117' date='Feb 13 ...   Feb 13 2021, 08:49 PM
john77   It just dawned on me that maybe I could use cavity...   Feb 14 2021, 02:24 AM
mlindner   On mine John, lots of cleaning, some painting and ...   Feb 13 2021, 04:36 PM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Feb 14 2021, 02:26 AM
burton73   What do you think of fender liners? My 86 928 has...   Feb 13 2021, 07:08 PM
bkrantz   I dug out all the original foam on both sides from...   Feb 13 2021, 08:34 PM
raynekat   On my restoration/build, we dug all that foam out ...   Feb 13 2021, 10:06 PM
bbrock   On my restoration/build, we dug all that foam out...   Feb 13 2021, 11:22 PM
bkrantz   On my restoration/build, we dug all that foam out...   Apr 18 2021, 08:59 PM
Cairo94507   @john77 - I would seal that up the best way you c...   Feb 14 2021, 08:50 AM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 14 2021, 12:25 PM
john77   Thanks Brent. I ordered some raptor spray-on bedl...   Feb 15 2021, 10:49 AM
mate914   I removed all seam sealer and foam. Then coal blas...   Feb 14 2021, 09:05 AM
Geezer914   I second the use of bed liner. I undercoated the ...   Feb 14 2021, 09:07 AM
930cabman   I plan on removing the asphalt based undercoating ...   Feb 14 2021, 04:30 PM
mlindner   Sorry John missed your question. Its Polyethene ro...   Apr 18 2021, 07:14 AM
john77   Thanks @[url=http://www.914world.com/bbs2/index.p...   Apr 19 2021, 02:31 PM
Mikey914   We actually make these as a kit. Utilizing HDPE as...   Apr 18 2021, 07:37 AM
mb911   I made my own liners and happy with them so far.   Apr 19 2021, 06:41 AM
mlindner   John77, if you'd like I can send you a paper t...   Apr 20 2021, 04:18 AM
john77   That would be super helpful, thanks Mark! Jo...   Apr 20 2021, 12:06 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:10 PM
