sound deadening, engine compartment pad |
dlindzey |
Apr 25 2021, 08:49 AM
repeat offender Group: Members Posts: 33 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
there are at least two different versions on the usual parts sites-
aase $200 pelican $125 AA $200 any practical experience or obvious best choice in taking care of this need? |
Literati914 |
Apr 25 2021, 10:00 AM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Do you guys not worry about moisture getting trapped by these, even the stock ones?
Seems a press-on/sticky type would be better in that regard, if there's no concern for stock appearance.. but still, I'd be concerned. Fixing rust sucks. . |
Mark Henry |
Apr 25 2021, 01:24 PM
Do you guys not worry about moisture getting trapped by these, even the stock ones? Seems a press-on/sticky type would be better in that regard, if there's no concern for stock appearance.. but still, I'd be concerned. Fixing rust sucks. . No, my teen is always garaged and I try not to drive in the rain. Look at what stock is, look at the whole thing. hard rubber outer with the fiber (horsehair?), then the steel but your not done. The other side you have the fitted rubber/tar sheet glued to the firewall and the whole back pad. You take away any part of that sandwich and it will add noise. To me just some dynamat or whatever is crap, I'd look to replicate that sandwich with modern materials. It's going to have some weight, if it's a street car you have to live with that fact. |
bbrock |
Apr 25 2021, 02:18 PM
Do you guys not worry about moisture getting trapped by these, even the stock ones? Seems a press-on/sticky type would be better in that regard, if there's no concern for stock appearance.. but still, I'd be concerned. Fixing rust sucks. . No, my teen is always garaged and I try not to drive in the rain. Look at what stock is, look at the whole thing. hard rubber outer with the fiber (horsehair?), then the steel but your not done. The other side you have the fitted rubber/tar sheet glued to the firewall and the whole back pad. You take away any part of that sandwich and it will add noise. To me just some dynamat or whatever is crap, I'd look to replicate that sandwich with modern materials. It's going to have some weight, if it's a street car you have to live with that fact. (IMG:style_emoticons/default/agree.gif) 200% |
Lo-Fi Version | Time is now: 8th June 2024 - 04:45 AM |
