| tsvo |
Apr 26 2021, 06:02 AM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
Hello, I have a vibration that I can feel through the steering wheel, especially as speeds increase. I have had the alignment done, replaced the tires and replaced the struts.
Any suggestions on what to look for next? |
| Cairo94507 |
Apr 27 2021, 11:08 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
My front end had all the components replaced new. My wheels were freshly restored and had new tires. It took me getting them balanced 3 times to get them correct. Not all technicians are created equally when it comes to this task. One would think you just get the machine to read out 00 for needed weights but apparently not. I took my car to Roger Krause Racing in Castro Valley and they pulled all 4 wheels and each wheel was 1/2 to 3/4 of an ounce off. They stripped all weights off and rebalanced them to zero and now it rides glass smooth. So, just saying, maybe look at that. (IMG:style_emoticons/default/beerchug.gif)
| Justinp71 |
Apr 27 2021, 11:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
My front end had all the components replaced new. My wheels were freshly restored and had new tires. It took me getting them balanced 3 times to get them correct. Not all technicians are created equally when it comes to this task. One would think you just get the machine to read out 00 for needed weights but apparently not. I took my car to Roger Krause Racing in Castro Valley and they pulled all 4 wheels and each wheel was 1/2 to 3/4 of an ounce off. They stripped all weights off and rebalanced them to zero and now it rides glass smooth. So, just saying, maybe look at that. (IMG:style_emoticons/default/beerchug.gif) Thanks for the info, I have found this true as well. I have been battling this on and off with my 20 years of owning my car, the list-
tsvo Steering wheel vibration Apr 26 2021, 06:02 AM
914Sixer Rotors out of round? Loose wheel bearings? Apr 26 2021, 06:18 AM
tsvo
Tha... Apr 26 2021, 06:28 AM
Rand
Th... Jul 7 2021, 03:16 PM
Superhawk996 Two things come to mind.
1) Don't assume th... Apr 26 2021, 06:19 AM
tsvo
1) Don't assume t... Apr 26 2021, 06:28 AM
rfinegan
1) Don't assume t... Apr 26 2021, 09:09 AM
tsvo
[quote name='Superhawk996' post='2911083' date='A... Apr 26 2021, 12:09 PM
bdstone914 2) Wheels on 914's are lug centric.
@Supe... Apr 28 2021, 07:14 AM
oakdalecurtis I had the same problem.
Tie rod ends, replaced, m... Apr 26 2021, 09:27 AM
tsvo
Tie rod ends, replaced, ... Apr 26 2021, 12:09 PM
burlybryan FWIW, while the other examples mentioned are more ... Apr 27 2021, 08:17 AM
FWIW, while the other examples mentioned are more... Apr 27 2021, 08:48 AM
tsvo
FWIW, while the other examples mentioned are more... Apr 28 2021, 06:02 AM
tsvo
My front end had all the components replaced new... Apr 28 2021, 06:05 AM
Justinp71
[quote name='Justinp71' post='2911411' date='Apr ... Apr 28 2021, 09:43 AM
tsvo
My front end had all the components replaced new.... Apr 28 2021, 06:03 AM
rfinegan Also...What Wheels and tire Do you have? Apr 28 2021, 07:30 AM
Front yard mechanic Do the redneck trick stick your head out the windo... Apr 28 2021, 11:15 AM
Coondog I have been fighting this issue for a couple years... Apr 28 2021, 11:30 AM
Superhawk996
I have been fighting this issue for a couple year... Apr 28 2021, 04:28 PM
914Sixer It just dawned on me for what it is worth. The ol... Apr 28 2021, 04:50 PM
orthobiz Spinning the wheel while the car is jacked up and ... Jul 5 2021, 02:02 PM
AZBanks I have a similar issue.
At 60 to 90mph I will get... Jul 5 2021, 07:25 PM
Justinp71 I have been fighting this for along time on and of... Jul 6 2021, 12:20 AM
Cairo94507 @Coondog - Sorry, I did not see your comment. I ... Jul 7 2021, 07:36 AM
Shivers It sounds like you have been chasing this problem ... Jul 7 2021, 08:11 AM
Al Meredith I agree with a previous post ....I don't drive... Jul 7 2021, 12:17 PM
Rand
I agree with a previous post ....I don't driv... Jul 7 2021, 03:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
