> Steering wheel vibration
tsvo
post Apr 26 2021, 06:02 AM
Hello, I have a vibration that I can feel through the steering wheel, especially as speeds increase. I have had the alignment done, replaced the tires and replaced the struts.
Any suggestions on what to look for next?
Superhawk996
post Apr 26 2021, 06:19 AM
Two things come to mind.
1) Don't assume the wheels are balanced properly. Get a shop with a road force balancer to re-check. I won't go into details but there is a huge difference between old fashioned dynamic balnce and road force balancing.
https://www.discounttire.com/learn/road-force-balancing
2) Wheels on 914's are lug centric. You want to tighten the lug nuts progressively in an X-patttern to ensure they center properly on the lug nut balls. The shop that did the work may have used a impact gun to nail down 1 lug nut, than the other 3 all in a single step. Wheels could be running with excess radial runout.
Beyond that, there are all sorts of other possibilities like worn ball joints, struts, tie road ends, etc. If it started right after the tires were replaced, I'd start by verifying #1 and #2 above.
bdstone914
post Apr 28 2021, 07:14 AM
bdstone914
@Superhawk996
From mid 72 and on front hubs are hub centric.
Good advice otherwise.
Tangerine racing makes adapters to make rear hubs hub centric. But his problem does seem to be in the front.
tsvo   Steering wheel vibration   Apr 26 2021, 06:02 AM
914Sixer   Rotors out of round? Loose wheel bearings?   Apr 26 2021, 06:18 AM
tsvo   Rotors out of round? Loose wheel bearings? Tha...   Apr 26 2021, 06:28 AM
Rand   Rotors out of round? Loose wheel bearings? Th...   Jul 7 2021, 03:16 PM
Superhawk996   Two things come to mind. 1) Don't assume th...   Apr 26 2021, 06:19 AM
tsvo   Two things come to mind. 1) Don't assume t...   Apr 26 2021, 06:28 AM
rfinegan   Two things come to mind. 1) Don't assume t...   Apr 26 2021, 09:09 AM
tsvo   [quote name='Superhawk996' post='2911083' date='A...   Apr 26 2021, 12:09 PM
bdstone914   2) Wheels on 914's are lug centric. @Supe...   Apr 28 2021, 07:14 AM
oakdalecurtis   I had the same problem. Tie rod ends, replaced, m...   Apr 26 2021, 09:27 AM
tsvo   I had the same problem. Tie rod ends, replaced, ...   Apr 26 2021, 12:09 PM
burlybryan   FWIW, while the other examples mentioned are more ...   Apr 27 2021, 08:17 AM
mepstein   FWIW, while the other examples mentioned are more...   Apr 27 2021, 08:48 AM
tsvo   FWIW, while the other examples mentioned are more...   Apr 28 2021, 06:02 AM
Cairo94507   My front end had all the components replaced new. ...   Apr 27 2021, 11:08 AM
Justinp71   My front end had all the components replaced new....   Apr 27 2021, 11:17 AM
tsvo   My front end had all the components replaced new...   Apr 28 2021, 06:05 AM
Justinp71   [quote name='Justinp71' post='2911411' date='Apr ...   Apr 28 2021, 09:43 AM
tsvo   My front end had all the components replaced new....   Apr 28 2021, 06:03 AM
rfinegan   Also...What Wheels and tire Do you have?   Apr 28 2021, 07:30 AM
Front yard mechanic   Do the redneck trick stick your head out the windo...   Apr 28 2021, 11:15 AM
Coondog   I have been fighting this issue for a couple years...   Apr 28 2021, 11:30 AM
Superhawk996   I have been fighting this issue for a couple year...   Apr 28 2021, 04:28 PM
914Sixer   It just dawned on me for what it is worth. The ol...   Apr 28 2021, 04:50 PM
orthobiz   Spinning the wheel while the car is jacked up and ...   Jul 5 2021, 02:02 PM
AZBanks   I have a similar issue. At 60 to 90mph I will get...   Jul 5 2021, 07:25 PM
Justinp71   I have been fighting this for along time on and of...   Jul 6 2021, 12:20 AM
Cairo94507   @Coondog - Sorry, I did not see your comment. I ...   Jul 7 2021, 07:36 AM
Shivers   It sounds like you have been chasing this problem ...   Jul 7 2021, 08:11 AM
Al Meredith   I agree with a previous post ....I don't drive...   Jul 7 2021, 12:17 PM
Rand   I agree with a previous post ....I don't driv...   Jul 7 2021, 03:17 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:10 AM
