| tsvo |
Apr 26 2021, 06:02 AM
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest
Hello, I have a vibration that I can feel through the steering wheel, especially as speeds increase. I have had the alignment done, replaced the tires and replaced the struts.
Any suggestions on what to look for next? |
| Coondog |
Apr 28 2021, 11:30 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California
I have been fighting this issue for a couple years now. Tried everything listed above, road balanced 3 times before we solved 80% of the problem, even had the rims sent to FUCHS restoration. In fact my car is back at PMS to address this issue alone with other steering related issues. Maybe I need to follow Mikes advise and take a road trip to Roger Krause Racing in Castro Valley.
| Superhawk996 |
Apr 28 2021, 04:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I have been fighting this issue for a couple years now. Tried everything listed above, road balanced 3 times before we solved 80% of the problem, even had the rims sent to FUCHS restoration. In fact my car is back at PMS to address this issue alone with other steering related issues. Maybe I need to follow Mikes advise and take a road trip to Roger Krause Racing in Castro Valley. Short term flat spotting is a very real issue on modern tires post Firestone/Ford/TREAD Act fiasco. Design changes were driven into tire construction that compond the short term flatspotting issue. Occurs across all tire brands. Some constructions worse than others but it is there in all to some degree. Most temporary flat spotting will drive out in just a couple miles but there are constructions out there that require tires to get pretty warm and even then it still can take 5-10 miles for it to really settle down. If you are really having road balance issues, my preferred solution is drive them enought to get them very warm. Take all tires off the car, leave them on floor in horizontal orientation overnight (Don't stack all 4 vertically either), then do road force in the morning. Also worth noting some constructions have long term flatspotting that if left long enough (say about 6 weeks) it will never drive out. It won't be terrrible but it will be present and will not go away regardless of what you do. Is even worse if parked when hot, and then left for that extended duration. If you can't seem to get that last 20% try an on-car wheel balance. Getting hard to find shops that can or will do it but on-car balance accounts for all rotating imbalances including rotors, and/or rear axles & outboard CV's. https://www.tirerack.com/tires/tiretech/tec...ots%20to%20form. |
tsvo Steering wheel vibration Apr 26 2021, 06:02 AM
914Sixer Rotors out of round? Loose wheel bearings? Apr 26 2021, 06:18 AM
tsvo
Tha... Apr 26 2021, 06:28 AM
Rand
Th... Jul 7 2021, 03:16 PM
Superhawk996 Two things come to mind.
1) Don't assume th... Apr 26 2021, 06:19 AM
tsvo
1) Don't assume t... Apr 26 2021, 06:28 AM
rfinegan
1) Don't assume t... Apr 26 2021, 09:09 AM
tsvo
[quote name='Superhawk996' post='2911083' date='A... Apr 26 2021, 12:09 PM
bdstone914 2) Wheels on 914's are lug centric.
@Supe... Apr 28 2021, 07:14 AM
oakdalecurtis I had the same problem.
Tie rod ends, replaced, m... Apr 26 2021, 09:27 AM
tsvo
Tie rod ends, replaced, ... Apr 26 2021, 12:09 PM
burlybryan FWIW, while the other examples mentioned are more ... Apr 27 2021, 08:17 AM
FWIW, while the other examples mentioned are more... Apr 27 2021, 08:48 AM
tsvo
FWIW, while the other examples mentioned are more... Apr 28 2021, 06:02 AM
Cairo94507 My front end had all the components replaced new. ... Apr 27 2021, 11:08 AM
Justinp71
My front end had all the components replaced new.... Apr 27 2021, 11:17 AM
tsvo
My front end had all the components replaced new... Apr 28 2021, 06:05 AM
Justinp71
[quote name='Justinp71' post='2911411' date='Apr ... Apr 28 2021, 09:43 AM
tsvo
My front end had all the components replaced new.... Apr 28 2021, 06:03 AM
rfinegan Also...What Wheels and tire Do you have? Apr 28 2021, 07:30 AM
Front yard mechanic Do the redneck trick stick your head out the windo... Apr 28 2021, 11:15 AM
914Sixer It just dawned on me for what it is worth. The ol... Apr 28 2021, 04:50 PM
orthobiz Spinning the wheel while the car is jacked up and ... Jul 5 2021, 02:02 PM
AZBanks I have a similar issue.
At 60 to 90mph I will get... Jul 5 2021, 07:25 PM
Justinp71 I have been fighting this for along time on and of... Jul 6 2021, 12:20 AM
Cairo94507 @Coondog - Sorry, I did not see your comment. I ... Jul 7 2021, 07:36 AM
Shivers It sounds like you have been chasing this problem ... Jul 7 2021, 08:11 AM
Al Meredith I agree with a previous post ....I don't drive... Jul 7 2021, 12:17 PM
Rand
I agree with a previous post ....I don't driv... Jul 7 2021, 03:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:02 PM |
