| Wew |
Apr 28 2021, 09:49 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Engine rebuild has not gone as smooth as I had hoped. I am dropping the engine again to figure out the source of my leaks. I have drips coming from a couple of the tube on the passenger side under the oil cooler. Tough to tell if it's the cooler or the tubes. Cylinder 3 is giving me the most concern. It almost looks like one of the four cylinder studs is leaking oil. I can't tell exactly as it could be the actual mating surface of the cylinder and the block. Anyway I am dropping the motor to track these down. Has anyone else come across oil leaking out of a stud or is this just the cylinder and engine mating surface leaking? If it is how have any of you remedied this? Is there a bullet proof sealant that others have used to stop this? Attached is an image I borrowed online that shows the location of where I see oil coming from. Thanks for sharing as always. |
| Mark Henry |
Apr 30 2021, 06:42 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Looks like the PR tube at the head, then it's migrating down the tube and the cooling air blows it off in that spot. Or it could be a VC leak. Less common is leaking at the rocker stud.
But also check the oil pressure switch, etc. |
Wew Oil leaks after rebuild Apr 28 2021, 09:49 AM
Wew Are the 1973 2.0 engines supposed to have the push... Apr 28 2021, 12:48 PM
Mark Henry Where's the underside cooling tin?
What did y... Apr 28 2021, 02:27 PM
wonkipop
What did ... May 15 2021, 02:04 AM
Mark Henry
What did... May 15 2021, 05:09 AM
wonkipop
[quote name='wonkipop' post='2915960' date='May 1... May 15 2021, 09:52 PM
Wew Hi Mark,
I removed the tin to see the leaks.
I u... Apr 28 2021, 03:08 PM
76-914 Don't overlook the oil pressure sender or more... Apr 28 2021, 04:14 PM
Wew sage advice... Will check there as well.
I hate o... Apr 28 2021, 04:37 PM
Mark Henry So you took the pushrod tubes out to remove the ti... Apr 28 2021, 04:42 PM
Wew ahh...
That is a photo I borrowed from another us... Apr 28 2021, 04:46 PM
Mark Henry Okay as long as you have those tins, your engine a... Apr 28 2021, 06:32 PM
Wew Dropped the engine tonight.
That’s about all I c... Apr 28 2021, 08:03 PM
iankarr Four of the cylinder head bolts/studs pass through... Apr 28 2021, 08:16 PM
Wew Thanks for softening the blow Ian.
Mark, I could... Apr 28 2021, 09:25 PM
Wew Thanks Mark.
I removed the fan housing shroud.
... May 1 2021, 10:40 AM
Wew
Two examples of the set up from PO.
Consideri... May 2 2021, 12:24 PM
Mark Henry I personally would use a whip. That fitting and a ... May 2 2021, 12:54 PM
FlacaProductions If you want to keep the gauge, you may want to re-... May 2 2021, 12:58 PM
Wew That great info from both of you.
I got a better ... May 2 2021, 10:22 PM
76-914 So it was OP sender.That looks like it is chipped ... May 3 2021, 08:15 AM
Wew Yikes,
Not what I wanted to hear.
Can this be d... May 3 2021, 11:28 AM
Wew What are you thoughts on putting the sensor flush ... May 4 2021, 12:43 PM
Root_Werks Isn't there another galley you can unplug and ... May 4 2021, 01:56 PM
Shivers Before I gave up and started tearing it down. I... May 4 2021, 02:43 PM
Wew Two good points.
I have an appointment with a sho... May 5 2021, 09:18 AM
Root_Werks I would like to know the outcome of this leak. Ha... May 5 2021, 09:54 AM
Mark Henry Wew are you sure it's leaking from the switch?... May 15 2021, 05:19 AM
Superhawk996 Been there, done that with leaking oil pressure sw... May 15 2021, 08:48 AM
barefoot When i got my 911SC it had an oil leak I couldn... May 16 2021, 06:05 AM
Wew Hi all,
Sorry for the absence. Been away on vaca... May 17 2021, 02:32 PM
Wew Hi all,
I am back at putting my engine back toget... Jun 16 2021, 12:27 PM
ClayPerrine
I also had a tough time getting the banana muffl... Jun 16 2021, 12:51 PM
Wew Hi all,
Engine back in and running better after v... Jun 29 2021, 07:38 PM
Wew I just looked at some torque specs for the oil pre... Jun 29 2021, 10:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
