> Bosch 009/050 points and condensor, what to buy?
bbrock
post Apr 28 2021, 08:52 PM
I need to get a set of points and condenser for a Bosch 050 dizzy. It looks like the correct points (Bosch 01 030) have been NLA for a long time and even old stock has dried up. 01 011 (I believe these are the same as used in most stock 914 dizzies) will work and are available. So which condenser to get? I'm assuming Bosch 02 054 (also stock 914 part) to match the points rather than 02 086 which was original for these centrifugal dizzies. I'm also guessing it really doesn't matter, but what use is having access to the world's greatest 914 brain trust if you don't use it? (IMG:style_emoticons/default/biggrin.gif)
bbrock
post Apr 30 2021, 06:08 PM
Alright, here's the full story which I was avoiding because it doesn't put a certain person in a good light.
After researching dizzies for my carbed engine, I decided I wanted vacuum advance and an electronic ignition of some sort. The Pertronix SVDA looked like a good option, but when I learned people have used the 1.8L stock dizzy with good success, I looked at the advance curves of the various stock dizzies and didn't see a whole lot of difference, so I decided to refurbish my stock 2.0L dizzy, pull the FI triggers and replace with a block off plate and give it a go. An experiment for sure. This dizzy was fitted with a Pertonix III Ignitor (also an experiment since there have been some bad reviews) and I bought a matching Flamethrower coil. Now before one of you 123 snobs spouts off about how great they are, I didn't have the budget at the time, and I'm drawn to going FI before too long (yes, I know it means a cam switch). Before spending 123 money, I want to know it is going to be with me for the long haul.
Okay, so I plugged in my refreshed stock dizzy with Pertronix and the engine fired right up and popped and spit for 30 minutes of cam break-in. After balancing the carbs and dialing them in a bit, I had the engine idling smoothly and reving freely for awhile. Now, the engine fires up easily and idles smoothly as it comes up to temperature, but then begins to misfire and idle erratically as the tach bounces around like a drunken monkey. Is the issue the Pertronix, the dizzy, the coil, or something else? That's where the 050 comes in. I have a NOS 050 I bought 35 years ago and never used. My thinking is to plug it in and see if the engine runs better. If it does, then I will install the Pertronix in it and see what happens. And if that works, then.... You get the picture. I'm just trying to isolate the possibilities.
Now finally to the points. I swapped the flamethrower coil for an old spare I have so I didn't fry the points. The replacement went in 90 degrees from how I had the flamethrower mounted (you probably see where this is going). I was careful to plug the power and tach wires in correctly, but trying to static time the dizzy, I couldn't get the voltage to drop no matter where I turned it. Then I noticed the condenser wire was unplugged, so I quickly plugged it into the same side I had gotten used to being the negative side. Of course it wasn't the negative side and watched the points wire glow red hot and vaporize. Doh! Hence, the need for points to complete the trouble shooting.
That's my story and I'm stickin' to it (IMG:style_emoticons/default/biggrin.gif)
Superhawk996
post May 1 2021, 08:24 AM
QUOTE(bbrock @ Apr 30 2021, 08:08 PM) *
(IMG:style_emoticons/default/alfred.gif)
oops . . . didn't mean to open that sort of wound and to kick you while you're down.
It is a good story though (IMG:style_emoticons/default/laugh.gif)
I'm not convinced on the whole electronic ignition thing either since it has it's own list of pro & con. You're on the right track to sorting it out. (IMG:style_emoticons/default/smilie_pokal.gif)
ClayPerrine
post May 1 2021, 08:54 AM
QUOTE(Superhawk996 @ May 1 2021, 09:24 AM) *
I ran a pickup coil and igniter/coil assembly from a Toyota 22RE motor in a stock 914 distributor for years. It fired right off the point cam. I had to bend the mount bracket to fit in the distributor, but it was otherwise a bolt on. The Toyota stuff was incredibly reliable, never a failure in the whole time I had it. Got the parts for free off of JDM engines I installed in Toyotas during my time fixing cars.
I still have the parts in the attic. I removed it and went to a pertronix and a stock coil just because the owner of the car (Betty) wasn't overly fond of the look of Toyota parts on her Porsche.
Clay
Superhawk996
post May 1 2021, 11:13 AM
QUOTE(ClayPerrine @ May 1 2021, 10:54 AM) *
Clay
Now that sounds interesting. I trust Toyota design and quality control over a whole lot of aftermarket electronic ignition stuff. The idea that there is no reverse polarity protection and/or the units can overheat from leaving key on too long are really basic design flaws in my book.
I'll have to dig in on the Toyota option.
The main thing for me is I've never quite seen the benefit of replacing the points only to leave a fickle rotor, and distributor cap behind. I've sort of always been in favor or all in on modern FI and direct ignition or just staying vintage points and distributor.
Not trying to change anyones mind. Just a personal preference.
I did see Dub Shop had a replacement for the distributor to establish cam timing. Having both crank and cam signals brings potential to Microsquirt and other aftermarket FI systems to do direct ignition. Currently sold out but looks like he's working on V2. (IMG:style_emoticons/default/piratenanner.gif)
http://thedubshop.com/mini-cam-sync/
ClayPerrine
post May 2 2021, 12:41 PM
QUOTE(Superhawk996 @ May 1 2021, 12:13 PM) *
Just get a late model Vanagon hall effect distributor. It is a drop in replacement that works great with Microsquirt.
https://www.busdepot.com/300920e
Clay
Superhawk996
post May 2 2021, 01:43 PM
QUOTE(ClayPerrine @ May 2 2021, 02:41 PM) *
Clay
Interesting option but my goal would be to eliminate the distributor completely. My point of view is that there is little sense in elimination of the points but leaving behind the rotor and cap. Direct ignition is the way to go. Coil on plug as would be even better. I'm still partial to you Toyota suggestion if I were to do anything, but, like knowing there are other options out there! Thanks Clay!
bbrock   Bosch 009/050 points and condensor   Apr 28 2021, 08:52 PM
larryM   Have these - $35 plus ship for all 914-4 IG...   Apr 29 2021, 09:42 PM
914Sixer   Use 911 points, they are equal to the tiger stripe...   Apr 30 2021, 06:35 AM
brant   Check the vw places. Cip. Etc There were afterma...   Apr 30 2021, 07:22 AM
bbrock   Thanks all. Is it important to match the condense...   Apr 30 2021, 07:49 AM
Superhawk996   Thanks all. Is it important to match the condens...   Apr 30 2021, 08:11 AM
Al Meredith   I got my 050 parts from "www.allzim.com...   Apr 30 2021, 08:54 AM
914werke   why points?   Apr 30 2021, 01:10 PM
Superhawk996   why points? The real question for @[url=http:/...   Apr 30 2021, 05:25 PM
930cabman   why points? I like points, sure they are not as...   May 1 2021, 06:40 PM
bbrock   Alright, here's the full story which I was avo...   Apr 30 2021, 06:08 PM
Superhawk996   That's my story and I'm stickin' to ...   May 1 2021, 08:24 AM
bbrock   That's my story and I'm stickin' to...   May 1 2021, 08:53 AM
ClayPerrine   That's my story and I'm stickin' to...   May 1 2021, 08:54 AM
Superhawk996   I ran a pickup coil and igniter/coil assembly f...   May 1 2021, 11:13 AM
bbrock   The idea that there is no reverse polarity protec...   May 1 2021, 12:45 PM
ClayPerrine   I did see Dub Shop had a replacement for the dis...   May 2 2021, 12:41 PM
Superhawk996   I did see Dub Shop had a replacement for the di...   May 2 2021, 01:43 PM
bbrock   Well, the Pertronix III seems to be working just f...   May 1 2021, 05:43 PM
MarkV   I think you will find that the advance curve on a ...   May 2 2021, 06:31 PM
bbrock   I think you will find that the advance curve on a...   May 2 2021, 06:44 PM
MarkV   Maybe the advance is different on an SVDA. There i...   May 2 2021, 07:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:23 PM
