| bbrock |
Apr 28 2021, 08:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I need to get a set of points and condenser for a Bosch 050 dizzy. It looks like the correct points (Bosch 01 030) have been NLA for a long time and even old stock has dried up. 01 011 (I believe these are the same as used in most stock 914 dizzies) will work and are available. So which condenser to get? I'm assuming Bosch 02 054 (also stock 914 part) to match the points rather than 02 086 which was original for these centrifugal dizzies. I'm also guessing it really doesn't matter, but what use is having access to the world's greatest 914 brain trust if you don't use it? (IMG:style_emoticons/default/biggrin.gif)
| MarkV |
May 2 2021, 07:00 PM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Maybe the advance is different on an SVDA. There isn't enough total advance in an 050 if I remember correctly. I am sure if you could find someone with a distributor machine you could get any of the to work correctly. I can tell you there is a night and day difference between a poorly set up distributor and one that is set correctly. |
bbrock Bosch 009/050 points and condensor Apr 28 2021, 08:52 PM
larryM Have these - $35 plus ship for all
914-4 IG... Apr 29 2021, 09:42 PM
914Sixer Use 911 points, they are equal to the tiger stripe... Apr 30 2021, 06:35 AM
brant Check the vw places.
Cip. Etc
There were afterma... Apr 30 2021, 07:22 AM
bbrock Thanks all. Is it important to match the condense... Apr 30 2021, 07:49 AM
Superhawk996
Thanks all. Is it important to match the condens... Apr 30 2021, 08:11 AM
Al Meredith I got my 050 parts from "www.allzim.com... Apr 30 2021, 08:54 AM
914werke why points? Apr 30 2021, 01:10 PM
Superhawk996
why points?
The real question for @[url=http:/... Apr 30 2021, 05:25 PM
930cabman
why points?
I like points, sure they are not as... May 1 2021, 06:40 PM
bbrock Alright, here's the full story which I was avo... Apr 30 2021, 06:08 PM
Superhawk996
That's my story and I'm stickin' to ... May 1 2021, 08:24 AM
bbrock
That's my story and I'm stickin' to... May 1 2021, 08:53 AM
ClayPerrine
That's my story and I'm stickin' to... May 1 2021, 08:54 AM
Superhawk996
I ran a pickup coil and igniter/coil assembly f... May 1 2021, 11:13 AM
bbrock
The idea that there is no reverse polarity protec... May 1 2021, 12:45 PM
ClayPerrine
I did see Dub Shop had a replacement for the dis... May 2 2021, 12:41 PM
Superhawk996
I did see Dub Shop had a replacement for the di... May 2 2021, 01:43 PM
bbrock Well, the Pertronix III seems to be working just f... May 1 2021, 05:43 PM
MarkV I think you will find that the advance curve on a ... May 2 2021, 06:31 PM
bbrock
I think you will find that the advance curve on a... May 2 2021, 06:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:25 PM |
