FS Headlight Installation Hardware kits |
bdstone914 |
Oct 25 2020, 09:38 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have assembled two different kits for headlight installation.
The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. Attached thumbnail(s) |
DRPHIL914 |
May 3 2021, 07:35 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have assembled two different kits for headlight installation. The A Kit includes: (6) 4mm SS allan head socket screws and washers to attach the ring to the headlight frame. The original phillips head screws are prone to stripping out the heads. The allan heads allow more secure installation to prevent them from dropping down the bucket. The washers distribute the load on the tab for less distortion. (6) 4.2 mm SS oval head screws to attach the cover to the frame. (6) 4.2 mm SS flat head countersunk screws to attach the headlight surrounds. Cost $12.50 shipped. The Kit B includes all of the above and (10) 4.2 zinc plated Tinnerman clips. cost $17.50 shipped. Each kit is enough to do both headlights. The picture shows 12 clips but only 10 are needed and included. several kits available now and will be offered ongoing Kit C will be for the installation of the headlight pivot brackets with (4) new yellow zinc plated plates 6mm allan head screws, hardened flat washers, and star washers. I am short on the washers and bolts but they are on order. Price is $30 for kit C. Or $25 if ordered with any other kit. @bdstone914 Bruce, do you have any of these full kits in stock? also do you have the pivot brackets? Phil |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:01 AM |
