| bkrantz |
May 4 2021, 06:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
In theory, sealant on all the mating surfaces for the engine case halves should contain oil and prevent leaks, and (with a couple of exceptions) the design of nuts and bolts, and where they attach, was not intended to form a seal.
But many mechanics swear by applying lots of sealant to every piece of case hardware. Is this overkill? Anyone had good luck lately with just sealant on the case halves? |
| Shivers |
May 4 2021, 07:29 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi Clay. I googled Drei-Bond, haha could you post the numbers off the tube. They make a lot of sealants evidently. Never thought about it, but those case halves can move a tiny bit.
| ClayPerrine |
May 4 2021, 10:33 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Hi Clay. I googled Drei-Bond, haha could you post the numbers off the tube. They make a lot of sealants evidently. Never thought about it, but those case halves can move a tiny bit. It is Drei-Bond 1209. I had to switch computers to look it up. The bird has it.... https://www.pelicanparts.com/More_Info/0000...1IaAixUEALw_wcB And I know other vendors have it as well. Clay |
bkrantz Sealing Engine Case Hardware? May 4 2021, 06:55 AM
ClayPerrine I use a thin bead of Drei-Bond. It is the adhesiv... May 4 2021, 07:20 AM
Mark Henry My newest favorite is loctite si 5900, factory spe... May 4 2021, 08:16 AM
Superhawk996
But many mechanics swear by applying lots of sea... May 4 2021, 08:46 AM
Mark Henry
But many mechanics swear by applying lots of se... May 5 2021, 05:19 AM
ClayPerrine
No sealeant under the washers sounds great in th... May 5 2021, 05:51 AM
Shivers Thanks Clay May 4 2021, 12:25 PM
johnhora Have had good results with these over time...
Old... May 4 2021, 02:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:30 PM |
