| VaccaRabite |
Apr 25 2021, 12:53 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,914 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I broke the plug to my idle control valve. I bought a new plug housing. Easy. But I’ve had a devil of a time finding the right socket pins for the housing. Several weeks have been stalled waiting for 80 cents worth of pins that show up and are the wrong size. So, knowing the 914 has to drive next weekend, I went full DACO and soldered a pigtail of wires into the ICV and then crimped them into place. About to find out if it works, and will continue to work for a couple weeks while I sleuth out the right sockets for the plug Wish me luck! Zach |
| VaccaRabite |
May 4 2021, 06:54 AM
After reading this thread:
http://www.914world.com/bbs2/index.php?showtopic=244849 I bought a new 52mm Throttle Body from Bus Labs. This unit: I looked at the GoWesty unit which is more stock looking, but they were not currently available. And the 2.1 Vanagon TBs I found all needed rebuilding if I bought them on Ebay. So my plan: I have a 400 mile drive coming up Memorial day weekend. If everything goes to crap, I plug my old TB back in and do it, and deal with an occasional high idle and knowing that I'm leaving almost 10% of power on the table at WOT. BUT if the new unit arrives on time, I have plenty of time to make a mount for my TPS (since I can't use the 2 position switch the Vanagon uses), expand the horn on the plenum, mount the unit and get at least one test drive in to collect data for James to adjust the tune if needed. Somehow its always a rush.... lol. I'm sure the day I leave I'll have the car on the lift to change SOMETHING last minute. Zach |
| JamesM |
May 4 2021, 08:48 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,304 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
After reading this thread: http://www.914world.com/bbs2/index.php?showtopic=244849 I bought a new 52mm Throttle Body from Bus Labs. This unit: Let me know how this works out. It has been many years since I did mine using the stock 2.1 50mm throttle body, but I vaguely remember having to swap the arm on the throttle shaft for the one off the 1.8 in order to get the proper orientation. Hoping the aftermarket shaft is of the same design to allow this. |
| VaccaRabite |
May 4 2021, 10:47 AM
Let me know how this works out. It has been many years since I did mine using the stock 2.1 50mm throttle body, but I vaguely remember having to swap the arm on the throttle shaft for the one off the 1.8 in order to get the proper orientation. Hoping the aftermarket shaft is of the same design to allow this. I figured it may just be easier to move the throttle cable to the centerline using something similar to the set up I used when I had carbs. I’ll be able to play with it more when I get it. Zach |
VaccaRabite Idle control and maybe intake leaks Apr 25 2021, 12:53 PM
73-914 Sometimes you gotta do what you gotta do Apr 25 2021, 12:56 PM
Mark Henry My '67 bus I broke the shift rod coupler 1500 ... Apr 25 2021, 01:13 PM
Montreal914 :popcorn: Apr 25 2021, 05:31 PM
Beebo Kanelle Once, whilst stranded in Mexico, I had to build a... Apr 25 2021, 05:54 PM
VaccaRabite Bought another IAC and found a proper plug and pig... Apr 25 2021, 08:22 PM
JamesM
Bought another IAC and found a proper plug and pi... Apr 26 2021, 01:48 PM
Mark Henry :agree:
The SDS in my bug doesn't even have a... Apr 26 2021, 04:07 PM
VaccaRabite 1BbU4JeyzMo
Found an air leak on the throttle bod... May 1 2021, 01:15 PM
Superhawk996 Nice job.
:D May 1 2021, 02:44 PM
VaccaRabite I am leaning towards replacing the TB with the lar... May 1 2021, 04:11 PM
BeatNavy You can ream out that shaft bushing in the TB and ... May 1 2021, 04:24 PM
VaccaRabite I have the Raby version of the Web494 carb cam. Hi... May 1 2021, 09:28 PM
nditiz1 Zach, please send build details of the smoke machi... May 4 2021, 07:23 AM
VaccaRabite tixozqgSwN0
He has a complete parts listing in th... May 4 2021, 08:34 AM
VaccaRabite The GoWesty unit is pretty awesome, and converting... May 7 2021, 06:19 PM
VaccaRabite After my test drive tonight the idle was still a l... May 8 2021, 08:37 PM
Montreal914 Zack, really cool writeup! Thank you for shari... May 9 2021, 11:47 AM
VaccaRabite
Zack, really cool writeup! Thank you for shar... May 9 2021, 06:14 PM
Montreal914
Zack, really cool writeup! Thank you for sha... May 9 2021, 09:18 PM
VaccaRabite This topic came up again recently so I thought I... Dec 1 2021, 10:01 AM
DRPHIL914 @[url=http://www.914world.com/bbs2/index.php?showu... Dec 1 2021, 10:22 AM
r_towle
This topic came up again recently so I thought I... Apr 15 2022, 08:21 PM
VaccaRabite Dunno. I did not have 2.0 induction gear to work ... Dec 1 2021, 03:24 PM
DRPHIL914 i am bumping this thread again for the purpose of ... Mar 16 2022, 08:05 AM
Frank S
i am bumping this thread again for the purpose of... Mar 16 2022, 10:24 AM
JamesM
i am bumping this thread again for the purpose of... Mar 16 2022, 05:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th September 2026 - 08:08 PM |
