| Olympic 914 |
May 6 2021, 08:25 AM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Just got back from having the teener run on a Dyno.
Good and not as good as I expected. Was hoping for at least 100 Hp, didn't make it. This run was on a Mustang Dyno, allegedly a Dynojet Dyno reads from 12~15% higher. First the good. Runs were extremely consistent. the three runs printed pretty much right on top of each other. Torque was way up there above 95 tq from 3000 to 4500. with no real dips. HP numbers were very consistent with a nice smooth line from 2000 to over 4500 Now the bad Max HP was only read at 88 Hp and max torque was 100. If I add the 12-15% it comes to 100 Hp. But it is what it is. Build is 2056 D-jet, Heads by HAM RS+, 8.6 comp. Raby 9590 cam, SS HEs with Triad muffler. I Have adjusted the MPS to what seems to run best for this car. This car runs great and I just wanted to know what it was putting out, Not really planning to try to tune it for more power. Reliability is the key. and I am so far happy with that. Dyno sheet added (Date/time is wrong, 5/06/21 8:35am) ![]() |
| Tom_T |
May 6 2021, 12:05 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
FYI by comparison for what you should be able to beat with your 2056 ....
The GA 2.0 USA stock 2.0L had better than your 88 max HP & 100 max TQ - with 116 lb/ft @ 3500 RPM & 95 HP @ 4900 RPM (DIN spec numbers) - https://www.excellence-mag.com/resources/specs/367 . FYI - Porsche USA stock numbers chart: ![]() .... IIRC this is from the Porsche Chart(s) & made up by p914.com 1973 Owners Manual - with SAE 91 HP @ 4900 RPM, & 105 lb/ft @ 3500 RPM TQ numbers (ergo difference with Excellence's DIN numbers at the link above) - . IIRC SoCalAndy's (Andy T) prior yellow `72 914/4 with a twin 2-throat Carb (Weber?) 2056 cc turned out 125 HP, from what he told me - but that was +/- 7 years ago (prior to his current M471 yellow -6). So maybe the current owner of that car &/or Andy T may know his old 2056's numbers, & whether it was crank or rear wheel. Unfortunately I'm not finding my Euro Version performance chart for the their GB 2.0L with 100 HP & XXX TQ at RPM Curves - so maybe someone else who has it can post it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// Attached thumbnail(s) |
| SirAndy |
May 6 2021, 01:01 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
with 116 lb/ft @ 3500 RPM & 95 HP @ 4900 RPM (DIN spec numbers) You say DIN and then proceed to show graphs with SAE ratings. (IMG:style_emoticons/default/rolleyes.gif) PS: 88/95 can get you into plenty of trouble. Plus, i take torque over HP any day. |
Olympic 914 Big Slice of Reality Pie. May 6 2021, 08:25 AM
VaccaRabite Just keep in mind that is your HP at the wheels. N... May 6 2021, 08:34 AM
Root_Werks There's still more power to be had with that b... May 6 2021, 08:48 AM
rfinegan That TQ looks great. I bet it drives and pulls gre... May 6 2021, 09:02 AM
Root_Werks
That TQ looks great. I bet it drives and pulls gr... May 6 2021, 09:44 AM
GregAmy That's really not hateful...did you do a ... May 6 2021, 09:53 AM
Jamie
Just got back from having the teener run on a Dyn... May 6 2021, 10:00 AM
JamesM Were they monitoring your AFRs during the pulls?
Olympic 914
... May 6 2021, 11:32 AM
JamesM
He said it was in the md- high 11s at WOT.
So ... May 6 2021, 10:47 PM
Mark Henry
Were they monitoring your AFRs during the pulls?... May 7 2021, 06:26 AM
brant I was going to ask if there were any AFR charts al... May 6 2021, 10:46 AM
Tom_T Changing to & properly tuning for the Euro 8.0... May 6 2021, 11:22 AM
GregAmy For Greg - a buddy here in SoCal has a FAT 2056 wi... May 6 2021, 11:29 AM
GregAmy ...have a good VE table tuned to ~14.5 mid-throttl... May 6 2021, 11:53 AM
rfinegan Not valve float @4500 May 6 2021, 11:52 AM
Olympic 914
88/95 can get you into plenty of trouble. Plus,... May 6 2021, 02:32 PM
GregAmy Don't forget that the standard for manufacture... May 6 2021, 12:24 PM
Tom_T
Don't forget that the standard for manufactur... May 6 2021, 12:41 PM
Tom_T PS & slightly OT - of note on that p914 perfor... May 6 2021, 12:27 PM
Olympic 914 Well my Butt Dyno said this engine had more than 1... May 6 2021, 01:21 PM
mbseto
... Plus, i take torque over HP any day.
When t... May 6 2021, 02:05 PM
mb911 Well I can tell you this. Though the Triads and an... May 6 2021, 05:29 PM
DRPHIL914
Well I can tell you this. Though the Triads and a... May 7 2021, 09:00 AM
mb911
[quote name='mb911' post='2913855' date='May 6 20... May 7 2021, 09:56 AM
Frank S
Well I can tell you this. Though the Triads and a... May 7 2021, 10:00 AM
iankarr I'm also in the torque over HP camp. And my cu... May 7 2021, 06:05 AM
76-914
I'm also in the torque over HP camp. And my c... May 7 2021, 08:00 AM
Montreal914
I'm also in the torque over HP camp. And my c... May 7 2021, 09:17 AM
Eric_Shea
I'm also in the torque over HP camp. And my c... May 12 2021, 06:33 AM
DRPHIL914
I'm also in the torque over HP camp. And my ... May 12 2021, 07:46 AM
76-914
[quote name='Eric_Shea' post='2915208' date='May ... May 12 2021, 08:03 AM
DRPHIL914
[quote name='Eric_Shea' post='2915208' date='May... May 12 2021, 08:41 AM
johnhora
Well I can tell you this. Though the Triads and a... May 7 2021, 07:19 AM
Bleyseng This is from 2000 when my 2.0L was stock with flat... May 7 2021, 12:40 PM
GregAmy A slight correction.
Microsquirt can be used whol... May 12 2021, 08:23 AM
DRPHIL914
Microsquirt can be used who... May 12 2021, 08:58 AM
GregAmy thanks for the info, good to know, btw looks grea... May 12 2021, 09:03 AM
bbrock
Great bedtime reading. Not for the TL;DR crowd.
... May 13 2021, 05:08 PM
GregAmy Followed your advice and read the whole thing last... May 13 2021, 07:49 PM
Mark Henry I have a real hard time believing that an EFI syst... May 12 2021, 12:00 PM
JamesM
I have a real hard time believing that an EFI sys... May 12 2021, 01:30 PM
914_teener
I have a real hard time believing that an EFI sy... May 12 2021, 02:13 PM
Mark Henry I don't care what is the best system, my probl... May 13 2021, 04:44 AM
914_teener
I don't care what is the best system, my prob... May 13 2021, 11:05 AM
JamesM
Since all the D-jet parts still have replacement... May 13 2021, 12:27 PM
Mark Henry
[quote name='Mark Henry' post='2915484' date='May... May 13 2021, 12:58 PM
GregAmy FWIW, my experience supports Mark's position.
... May 13 2021, 05:54 AM
JamesM
No, I didn't dyno the engine before replacin... May 13 2021, 12:17 PM
Bleyseng I have agree with Mark and Greg that I doubt that ... May 13 2021, 07:26 AM
Olympic 914 As stated in my first post..
the readings will de... May 13 2021, 07:48 AM
GregAmy I always use Dynapack. It controls the inertia/rat... May 13 2021, 09:22 AM
jd74914 @GregAmy Who do you typically use for a dyno shop... May 13 2021, 09:54 AM
GregAmy John Malepetsis, Performance and Styling in Manche... May 13 2021, 10:06 AM
jd74914
John Malepetsis, Performance and Styling in Manch... May 13 2021, 12:56 PM
Superhawk996 Best dyno accuracy is going to be an engine dyno. ... May 13 2021, 10:11 AM
914_teener James is right...and back to the OP.
Maybe and i... May 13 2021, 04:01 PM
Mark Henry
Maybe and ... May 14 2021, 04:54 AM
JmuRiz
For T4 I can and built reliable 160hp iron cylind... May 14 2021, 08:59 AM
Mark Henry
For T4 I can and built reliable 160hp iron cylin... May 14 2021, 09:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
