In Line 4 - The most Peculiar Problem, A bit off topic, however, I have run out of options |
ctc911ctc |
May 6 2021, 12:00 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All Teeners
You have helped me rebuild the '74 2.0. Every system has been rebuilt with your assistance. My son has purchased a 1991 Ranger. It blew a head gasket. Cyl 1 had NO pressure. We proceeded to take off the head took off all 10 bolts ( 2.3L Pinto/Mazada engine) off the head.... Hhhhmmm, does not budge - let's get the Wood Mallet That did not work (IMG:style_emoticons/default/confused24.gif) Hammer and wood? No, did not budge (IMG:style_emoticons/default/confused24.gif) Hand Sledge and wood No Did not budge (IMG:style_emoticons/default/confused24.gif) Then I put a bolt in the head on the front and on the block, tood a very large bearing spreader and cranked it until the bolts started to bend AND THEN hit it with the hand sledge Will not budge (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Within a RANGER forum a guy said that he had seen these WELDED together - I see no weld marks......really welded??? About to try the SNAKE IN THE HOLE trick using rope into the sparkplug hole once I get the CAM disconnected............... Any thoughts from the teener world please? (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
ctc911ctc |
May 7 2021, 07:01 AM
Thanks for all of the thoughtful responses - the head is attached with Bolts. They seem to be designed to stretch, the web site says use once, etc.
I will hook it to the beam today with perhaps 1000lbs of pull from above......will report back soon. Thank you TEENERS! |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:13 AM |
