In Line 4 - The most Peculiar Problem, A bit off topic, however, I have run out of options |
ctc911ctc |
May 6 2021, 12:00 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All Teeners
You have helped me rebuild the '74 2.0. Every system has been rebuilt with your assistance. My son has purchased a 1991 Ranger. It blew a head gasket. Cyl 1 had NO pressure. We proceeded to take off the head took off all 10 bolts ( 2.3L Pinto/Mazada engine) off the head.... Hhhhmmm, does not budge - let's get the Wood Mallet That did not work (IMG:style_emoticons/default/confused24.gif) Hammer and wood? No, did not budge (IMG:style_emoticons/default/confused24.gif) Hand Sledge and wood No Did not budge (IMG:style_emoticons/default/confused24.gif) Then I put a bolt in the head on the front and on the block, tood a very large bearing spreader and cranked it until the bolts started to bend AND THEN hit it with the hand sledge Will not budge (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Within a RANGER forum a guy said that he had seen these WELDED together - I see no weld marks......really welded??? About to try the SNAKE IN THE HOLE trick using rope into the sparkplug hole once I get the CAM disconnected............... Any thoughts from the teener world please? (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Shivers |
May 7 2021, 12:52 PM
Senior Member Group: Members Posts: 2,430 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
It's a cast iron engine, so you could try the flat blade screwdriver last resort method. The locating dowel pins can rust the hole thing together, so if the drop kick from the beam doesn't work, it may need a more local impact to get them to let go. I actually use a chisel when I must. Right at the head gasket. Good luck
Lo-Fi Version | Time is now: 9th June 2024 - 01:30 PM |
