Exhaust Stud not Holding in Crankcase |
RestoReese |
May 10 2021, 02:05 AM
Newbie Group: Members Posts: 31 Joined: 29-June 19 From: Dallas, TX Member No.: 23,256 Region Association: Southwest Region |
As title says, I have an exhaust leak because one of my stud holes in the case is stripped and will not hold. Tried loctite red, but didn't hold with tightening. Also, wasn't sure it would hold with the heat. Thought about JB weld but then reconsidered.
I know I can tap to a larger diameter but wondering if others have had a similar issue and what you would recommend. Any guidance would be helpful. Case is for 1971 1.7L. |
RolinkHaus |
May 10 2021, 04:18 AM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Recently, I used a helicoil on the exhaust which only lasted a week, broke into pieces. Timeserts are much stronger.
Lo-Fi Version | Time is now: 9th June 2024 - 12:21 AM |
