Running on 7 exhaust studs, Opinions needed wisdom optional |
wbgoggans |
May 10 2021, 09:26 PM
Member Group: Members Posts: 61 Joined: 22-April 20 From: Athens,GA Member No.: 24,167 Region Association: South East States |
To make a long story short... I had a bad exhaust leak. Bought new exhaust gaskets. Bought new exhaust studs to replace the exhaust bolts. When I tried to put one of the m8 exhaust studs into the one spot that had no exhaust bolt/ stud I found it to be much larger( damn you PO). I then went to the local parts store and bought the largest exhaust stud they had in stock ( m10). Even this is too small, so I’m estimating the po drilled it out to about an m12. Where can I even find an m12 exhaust stud? Am I going to have to have to settle for a bolt? Worst case scenario what are the odds I can get a good seal with just 7 exhaust studs? When will my project ever be done? What is the meaning of life? Should I just go ahead and buy a flat 6? I need answers!!!!
IronHillRestorations |
May 11 2021, 06:16 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I know some 1.8's use a stepped exhaust stud, which might make you think it had been drilled and tapped to larger size
Lo-Fi Version | Time is now: 1st June 2024 - 05:59 PM |
