> Oil leaks after rebuild, Dropping motor to track down oil leaks
Wew
post Apr 28 2021, 09:49 AM
Hi all,
Engine rebuild has not gone as smooth as I had hoped.
I am dropping the engine again to figure out the source of my leaks.
I have drips coming from a couple of the tube on the passenger side under the oil cooler.
Tough to tell if it's the cooler or the tubes.
Cylinder 3 is giving me the most concern.
It almost looks like one of the four cylinder studs is leaking oil.
I can't tell exactly as it could be the actual mating surface of the cylinder and the block.
Anyway I am dropping the motor to track these down.
Has anyone else come across oil leaking out of a stud or is this just the cylinder and engine mating surface leaking?
If it is how have any of you remedied this?
Is there a bullet proof sealant that others have used to stop this?
Attached is an image I borrowed online that shows the location of where I see oil coming from.
Thanks for sharing as always.
Mark Henry
post Apr 28 2021, 02:27 PM
that's what I do!
Where's the underside cooling tin?
What did you use to seal the cylinder to the case ?
Studs I put in with red loctite.
I'm happy if I have no drips, slight weeps are a given...it's an aircooled.
wonkipop
post May 15 2021, 02:04 AM
QUOTE(Mark Henry @ Apr 28 2021, 02:27 PM) *
i understand mark you are referring to what appears to be missing are the baffle tins located above the pushrod tubes normally and look like they are not there in the photo.
not warm air guides which are lower down?
i know back in the 80s there were two schools of thought on the lower warm air guides.
personally i believe the lower guides simply squirt or help direct the already heated cooling air that has done its job and try to direct that air towards the back of the car.
the big problem with a 914 is the heated air builds up under the car when it is at stand still in traffic idling compared to a regular rear engined VW where the air can just squirt out the rear without building up underneath. i know this because i live in australia and it can be very evident on a hot day here just how hot it can get underneath when the car is running but standing still. i'm not sure in the end the lower air guides do much really. maybe save the clutch and accelerator cables. i removed mine with the rusted out heat exchangers way back in the late 80s. the guides were rusted along with the heat exchangers. my american porsche mechanic back then explained what he believed the lower air guides did and it was 50 50 whether they really did push that hot air out from under the car any better than if they were not there.
it would be very dangerous to run a 914 engine without the baffle tin ware that is above the pushrods. those baffles are there to bend the air across the bottom of the cylinders and heads. thats going to cook an engine real fast if they are left off.
Mark Henry
post May 15 2021, 05:09 AM
that's what I do!
QUOTE(wonkipop @ May 15 2021, 04:04 AM) *
In the picture I was talking about the under cylinder (above PR) tin, I don't care if you live in Alaska you have to have these tins. The heat exchanger bottom tins I like to use up here in Canada, but it's not a must have. Obviously you can't even use the heat exchanger tins with headers.
Likely the pic the OP pulled from the net is from a DTM or Joe Cali upright fan conversion engine and these deflectors a modifided type1 and you can't see them in the pic.
Wew   Oil leaks after rebuild   Apr 28 2021, 09:49 AM
Wew   Are the 1973 2.0 engines supposed to have the push...   Apr 28 2021, 12:48 PM
Mark Henry   Where's the underside cooling tin? What did y...   Apr 28 2021, 02:27 PM
wonkipop   Where's the underside cooling tin? What did ...   May 15 2021, 02:04 AM
Mark Henry   Where's the underside cooling tin? What did...   May 15 2021, 05:09 AM
wonkipop   [quote name='wonkipop' post='2915960' date='May 1...   May 15 2021, 09:52 PM
Wew   Hi Mark, I removed the tin to see the leaks. I u...   Apr 28 2021, 03:08 PM
76-914   Don't overlook the oil pressure sender or more...   Apr 28 2021, 04:14 PM
Wew   sage advice... Will check there as well. I hate o...   Apr 28 2021, 04:37 PM
Mark Henry   So you took the pushrod tubes out to remove the ti...   Apr 28 2021, 04:42 PM
Wew   ahh... That is a photo I borrowed from another us...   Apr 28 2021, 04:46 PM
Mark Henry   Okay as long as you have those tins, your engine a...   Apr 28 2021, 06:32 PM
Wew   Dropped the engine tonight. That’s about all I c...   Apr 28 2021, 08:03 PM
iankarr   Four of the cylinder head bolts/studs pass through...   Apr 28 2021, 08:16 PM
Wew   Thanks for softening the blow Ian. Mark, I could...   Apr 28 2021, 09:25 PM
Mark Henry   Looks like the PR tube at the head, then it's ...   Apr 30 2021, 06:42 AM
Wew   Thanks Mark. I removed the fan housing shroud. ...   May 1 2021, 10:40 AM
Wew   Two examples of the set up from PO. Consideri...   May 2 2021, 12:24 PM
Mark Henry   I personally would use a whip. That fitting and a ...   May 2 2021, 12:54 PM
FlacaProductions   If you want to keep the gauge, you may want to re-...   May 2 2021, 12:58 PM
Wew   That great info from both of you. I got a better ...   May 2 2021, 10:22 PM
76-914   So it was OP sender.That looks like it is chipped ...   May 3 2021, 08:15 AM
Wew   Yikes, Not what I wanted to hear. Can this be d...   May 3 2021, 11:28 AM
Wew   What are you thoughts on putting the sensor flush ...   May 4 2021, 12:43 PM
Root_Werks   Isn't there another galley you can unplug and ...   May 4 2021, 01:56 PM
Shivers   Before I gave up and started tearing it down. I...   May 4 2021, 02:43 PM
Wew   Two good points. I have an appointment with a sho...   May 5 2021, 09:18 AM
Root_Werks   I would like to know the outcome of this leak. Ha...   May 5 2021, 09:54 AM
Mark Henry   Wew are you sure it's leaking from the switch?...   May 15 2021, 05:19 AM
Superhawk996   Been there, done that with leaking oil pressure sw...   May 15 2021, 08:48 AM
barefoot   When i got my 911SC it had an oil leak I couldn...   May 16 2021, 06:05 AM
Wew   Hi all, Sorry for the absence. Been away on vaca...   May 17 2021, 02:32 PM
Wew   Hi all, I am back at putting my engine back toget...   Jun 16 2021, 12:27 PM
ClayPerrine   I also had a tough time getting the banana muffl...   Jun 16 2021, 12:51 PM
Wew   Hi all, Engine back in and running better after v...   Jun 29 2021, 07:38 PM
Wew   I just looked at some torque specs for the oil pre...   Jun 29 2021, 10:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:46 PM
