| Wew |
Apr 28 2021, 09:49 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Engine rebuild has not gone as smooth as I had hoped. I am dropping the engine again to figure out the source of my leaks. I have drips coming from a couple of the tube on the passenger side under the oil cooler. Tough to tell if it's the cooler or the tubes. Cylinder 3 is giving me the most concern. It almost looks like one of the four cylinder studs is leaking oil. I can't tell exactly as it could be the actual mating surface of the cylinder and the block. Anyway I am dropping the motor to track these down. Has anyone else come across oil leaking out of a stud or is this just the cylinder and engine mating surface leaking? If it is how have any of you remedied this? Is there a bullet proof sealant that others have used to stop this? Attached is an image I borrowed online that shows the location of where I see oil coming from. Thanks for sharing as always. |
| Superhawk996 |
May 15 2021, 08:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Been there, done that with leaking oil pressure switch bore.
You're not going to like my solution. Not saying it's the only one but it made sense for me since I'm dealing with a bare case. Considered the other solutions (threaded inserts, taking hole out to 1/4 NPT, etc.) Might give you some other ideas. See post #182 http://www.914world.com/bbs2/index.php?sho...5209&st=181 Note: 1/8 NPT and M10x1.0 tapered pipe thread are almost exactly the same thread form both by OD and thread pitch. I've done the comparison on some other thread elsehwere on how little the thead pitch differs. For practial purposes they are interchangeable if you end up in a bind trying to select thread inserts, adapters, etc. As indicated by Mark above, make absolutely sure that is where it is leaking from before you go nuclear on it. I'd start with your 1st suggestion. See if you can get an ISO tapered pipe thread tap in M10 x 1.0 and tap it deeper to get more engaged threads. Failing that you can try the sealing washer if you can tap deep enough to get the flat base of the sensor to seal on the washer AND have enough threads to establish the needed clamp load. Here is an excerpt on difference between ISO taper and ISO straight threads: There are two variations of ISO pipe threads. Parallel threads (also called straight threads) and taper threads. Taper threads have a 1:16 taper and the same reamers can be used as for NPT threads. Reamers are not strictly necessary but in the larger sizes they enable a better thread to be produced. ISO pipe threads, when specified, are assumed to be parallel unless a taper thread is called out. Taper threads seal on the threads themselves. Parallel threads, if a leaktight fluid seal is required, seal with a gasket, washer, or O-ring against the female seat. Since there is only one thread pitch, the thread pitch is usually not specified and they are called out only by nominal size as noted below. From: https://www.womackmachine.com/engineering-t...t-thread-sizes/ |
Wew Oil leaks after rebuild Apr 28 2021, 09:49 AM
Wew Are the 1973 2.0 engines supposed to have the push... Apr 28 2021, 12:48 PM
Mark Henry Where's the underside cooling tin?
What did y... Apr 28 2021, 02:27 PM
wonkipop
What did ... May 15 2021, 02:04 AM
Mark Henry
What did... May 15 2021, 05:09 AM
wonkipop
[quote name='wonkipop' post='2915960' date='May 1... May 15 2021, 09:52 PM
Wew Hi Mark,
I removed the tin to see the leaks.
I u... Apr 28 2021, 03:08 PM
76-914 Don't overlook the oil pressure sender or more... Apr 28 2021, 04:14 PM
Wew sage advice... Will check there as well.
I hate o... Apr 28 2021, 04:37 PM
Mark Henry So you took the pushrod tubes out to remove the ti... Apr 28 2021, 04:42 PM
Wew ahh...
That is a photo I borrowed from another us... Apr 28 2021, 04:46 PM
Mark Henry Okay as long as you have those tins, your engine a... Apr 28 2021, 06:32 PM
Wew Dropped the engine tonight.
That’s about all I c... Apr 28 2021, 08:03 PM
iankarr Four of the cylinder head bolts/studs pass through... Apr 28 2021, 08:16 PM
Wew Thanks for softening the blow Ian.
Mark, I could... Apr 28 2021, 09:25 PM
Mark Henry Looks like the PR tube at the head, then it's ... Apr 30 2021, 06:42 AM
Wew Thanks Mark.
I removed the fan housing shroud.
... May 1 2021, 10:40 AM
Wew
Two examples of the set up from PO.
Consideri... May 2 2021, 12:24 PM
Mark Henry I personally would use a whip. That fitting and a ... May 2 2021, 12:54 PM
FlacaProductions If you want to keep the gauge, you may want to re-... May 2 2021, 12:58 PM
Wew That great info from both of you.
I got a better ... May 2 2021, 10:22 PM
76-914 So it was OP sender.That looks like it is chipped ... May 3 2021, 08:15 AM
Wew Yikes,
Not what I wanted to hear.
Can this be d... May 3 2021, 11:28 AM
Wew What are you thoughts on putting the sensor flush ... May 4 2021, 12:43 PM
Root_Werks Isn't there another galley you can unplug and ... May 4 2021, 01:56 PM
Shivers Before I gave up and started tearing it down. I... May 4 2021, 02:43 PM
Wew Two good points.
I have an appointment with a sho... May 5 2021, 09:18 AM
Root_Werks I would like to know the outcome of this leak. Ha... May 5 2021, 09:54 AM
Mark Henry Wew are you sure it's leaking from the switch?... May 15 2021, 05:19 AM
barefoot When i got my 911SC it had an oil leak I couldn... May 16 2021, 06:05 AM
Wew Hi all,
Sorry for the absence. Been away on vaca... May 17 2021, 02:32 PM
Wew Hi all,
I am back at putting my engine back toget... Jun 16 2021, 12:27 PM
ClayPerrine
I also had a tough time getting the banana muffl... Jun 16 2021, 12:51 PM
Wew Hi all,
Engine back in and running better after v... Jun 29 2021, 07:38 PM
Wew I just looked at some torque specs for the oil pre... Jun 29 2021, 10:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:40 PM |
